Get Battlezone?
joshk
Subject: Re: Looking for Battlezone PCB repair tips
Newsgroups: rec.games.video.arcade.collecting
Date: 2003-03-30 21:30:08 PST
I've worked on a few _Battlezone_ boardsets and here are some things I've
run across. Perhaps this can help...
*) Bad sockets. Very common problem on older Atari boards, specifically
beneath the ROMs. Can also happen underneath the 2901's on the auxiliary
board and the 6502.
*) Bad 2114 RAMs. If in doubt, replace them all. After 20 years, if one
original fails, the others probably aren't far behind. You don't want a
boardset coming back a week later.
*) Bad crystal. Sometimes it literally falls right off the board. If you
can't find the 12.096 MHz type, a 12.000 MHz should work just as well.
*) Bad solder joints on the cable connectors between the CPU board and
auxiliary board.
*) Bad PROMs on the aux board.
*) Bad 2901s on the aux board.
*) Bad video output circuitry on the CPU board. If the game plays blind,
look at the X OUT and Y OUT test points with an X/Y oscilloscope and see if
you have a bad video output. Could be just a bad op-amp. Sometimes the
adjustment pots in this area have broken legs or are missing entirely.
The full service manual can be ordered from QuarterArcade here:
http://www.quarterarcade.com/Game.aspx/149...l.Parts.Manuals
