calfranklin0598 Posted November 18, 2023 Share Posted November 18, 2023 I have an older Genius Mouse GM-6000 that has what appears to be an Atari connector and was wondering if anyone has successfully used this mouse with the 520/1040STFM computer? Quote Link to comment https://forums.atariage.com/topic/357009-genius-mouse-gm-6000-st-compatibility-inquiry/ Share on other sites More sharing options...
snarkdluG Posted November 18, 2023 Share Posted November 18, 2023 (edited) Probably a serial (rs-232) mouse for PC. So you can use it on Atari with a driver and connected to the serial port. But with an adapter since Atari serial port is 25 pin. And since it will need a driver, it will have somewhat limited use. Edited November 18, 2023 by snarkdluG Quote Link to comment https://forums.atariage.com/topic/357009-genius-mouse-gm-6000-st-compatibility-inquiry/#findComment-5351220 Share on other sites More sharing options...
calfranklin0598 Posted November 19, 2023 Author Share Posted November 19, 2023 Thanks for comment. Quote Link to comment https://forums.atariage.com/topic/357009-genius-mouse-gm-6000-st-compatibility-inquiry/#findComment-5351639 Share on other sites More sharing options...
