AdvSkelVic65/Atari disk: save game locks up emulator
Hi!  I've been updating AdvSkelVic65 with save game support, and the CBM versions seem to be working properly but not the Atari disk version.  :(  The program locks up between getting the game letter and opening the file.  The erroneous code follows:
[code]
char gamefilename[]="D1:SAVEADVA.ADV";
static const unsigned char gamefilenumpos=10;
static unsigned char __fastcall__ GetSaveLetter (unsigned char issave)
    printtok ("Insert game disk.\n"
        "Type in letter of the game to ");
    printtokcr (issave?"save":"load");
    i=getkey();
    if (i<'a' || i>='z'+1) {gamefilename[gamefilenumpos]=i|0x60; return 0;}
    return 1;
void vSave (void)
    if (!GetSaveLetter(1)) return;
    // s=c;
    printu(cio_open (3, &gamefilename, 4));
    // cbm_open (CBM_WRITE);
    cio_write (3, &Player, sizeof (Player));
    cio_write (3, &CRoom, 1);
    cio_close (3);
void vLoad (void)
    if (!GetSaveLetter(0)) return;
    // s=c;
    if (cio_open (4, &gamefilename, 8)) goto err;
    if (cio_read (4, &Player, sizeof (Player))) goto err;
    if (cio_read (4, &CRoom, 1)) goto err;
    if (cio_close (4)) goto err;
    printtokcr ("Loading succcessful!"); vLook2(); return;
err:
    printtokcr ("Error during load: player info might be corrupt!");
}[/code]I'm using cc65 and my AtaDisk65 library.
gamefilename is a char pointer, so you don't need address of &gamefilename, shouldn't be the issue, but just thought I would let you know.
Have no idea what your functions expect, so I think help on this will be limited.
As a first step, I would change the I/O functions to the built in ones and see if you still have the issue.
This line seems to put a lowercase letter into the filename:- if (i<'a' || i>='z'+1) {gamefilename[gamefilenumpos]=i|0x60
Again as I don't know what your functions are doing, this may cause an issue.
I tried fopen() and fwrite() and got the same result.  :(  Following is the vew save code:
[code]
void vSave (void)
    FILE* f;
//printc ('.');
printscr (&gamefilename);
    // s=c;
    //printu(cio_open (3, &gamefilename, 4));
    f=fopen (gamefilename, "rb");
    fwrite (&Player, sizeof (Player), 1, f);
    fwrite (&CRoom, 1, 1, f);
    fclose (f);
    // cio_write (3, &Player, sizeof (Player));
    // cio_write (3, &CRoom, 1);
    // cio_close (3);
}[/code]
Maybe it's the DOS I'm using.  Should I post the disk image?
BTW, if you want, I can post a link to AtaDisk65 so you can try it out.
