phoney Posted November 30, 2023 Share Posted November 30, 2023 I'm writing an app which involves navigating a text cursor freely around the screen with the joystick. I can obviously have the joystick change X and Y values for position, and print an inverse space to be the cursor. But I need to store the character that was previously in the location before I overwrote it with the 'cursor' so I can put it back when I move the 'cursor.' What address do I PEEK to find the character at a particular X and Y location in graphics 0? Thanks. Quote Link to comment Share on other sites More sharing options...
Rybags Posted November 30, 2023 Share Posted November 30, 2023 Basic has the LOCATE X,Y,C statement that will return what colour/character is at that location. Otherwise you could just PEEK the memory location. The formula for would be SC=PEEK(88)+PEEK(89)*256 CA=SC+X+Y*40 Note that if you're talking text window with a graphics mode that these won't work, you'd need to refer to the locations relevant to that. Also - LOCATE will return ASCII code, PEEK will give screen character code which in most cases will be different. Quote Link to comment Share on other sites More sharing options...
Gury Posted December 1, 2023 Share Posted December 1, 2023 This link includes an example (Moving Cursor With Joystick). It is a small Atari BASIC program with machine language routine. I hope it helps. Quote Link to comment Share on other sites More sharing options...
Gury Posted December 1, 2023 Share Posted December 1, 2023 1 REM ******************************* 2 REM PROGRAM : MOVING CURSOR WITH 3 REM JOYSTICK 4 REM AUTHOR : ZLATKO BLEHA 5 REM PUBLISHER: MOJ MIKRO MAGAZINE 6 REM ISSUE NO.: 1988, NO.6, PAGE 42 7 REM ******************************* 10 FOR A=1600 TO 1653 20 READ B:POKE A,B:C=C+B 30 NEXT A 40 IF C<>5925 THEN ? "*** DATA ERROR * **":END 50 POKE 512,64:POKE 513,6:POKE 54286,1 92 60 POKE PEEK(560)+PEEK(561)*256+6,130 70 DATA 72,138,72,186,138,72,206,117,6 ,208 80 DATA 27,169,4,141,117,6,162,8,189,1 07 90 DATA 6,205,120,2,208,8,189,108,6,14 1 100 DATA 252,2,208,4,202,202,208,236,1 04,170 110 DATA 154,104,170,104,64,7,135,11,1 34 120 DATA 14,142,13,143,4 1 Quote Link to comment Share on other sites More sharing options...
