Karadoc Posted December 10, 2023 Share Posted December 10, 2023 Hi, I'd purchased a Space Invaders in box to play on my 2600+ But the problem it's that it seems to be an empty cartridge Is it the case or i have to do something to manage playing with it? Thanks for answers Cheers from France An old fashionned Atari ST User Quote Link to comment Share on other sites More sharing options...
Karadoc Posted December 10, 2023 Author Share Posted December 10, 2023 Hello thanks to an US Atarist on bluesky i manage to play the game You can close this topic Quote Link to comment Share on other sites More sharing options...
Brad_from_the_80s Posted December 10, 2023 Share Posted December 10, 2023 Well it's an old one, but Space Invaders should work fine. Why do you think it's empty? Doesn't really look tampered with, from what I can see. If you gently but firmly push a very small screwdriver or something through one of those little windows you can push the internal door down and it will let you push the spring-loaded dust cover into the cartridge, revealing the circuit board contacts. They may just need cleaning. Unless it really is empty for some reason, no sure how to explain that one. Quote Link to comment Share on other sites More sharing options...
Karadoc Posted December 10, 2023 Author Share Posted December 10, 2023 2 minutes ago, Brad_from_the_80s said: Well it's an old one, but Space Invaders should work fine. Why do you think it's empty? Doesn't really look tampered with, from what I can see. If you gently but firmly push a very small screwdriver or something through one of those little windows you can push the internal door down and it will let you push the spring-loaded dust cover into the cartridge, revealing the circuit board contacts. They may just need cleaning. Unless it really is empty for some reason, no sure how to explain that one. the game works i'm an absolute noob on this console i didn't know that i've just to push well and the connection appears Thanks for the answer And sorry for this fake alert I'm a 16 bits user ^^ Quote Link to comment Share on other sites More sharing options...
MysticSword Posted December 10, 2023 Share Posted December 10, 2023 @KaradocAs Brad mentions, you just might not see the contacts as some cartridges will have a protective enclosure (such as Space Invaders) and it may need a cleaning like mentioned. Here's a little video I made recently about cleaning Atari 2600 cartridges and an example of how to access the contacts for cleaning (and on the ones that have the protective enclosure). 1 Quote Link to comment Share on other sites More sharing options...
Karadoc Posted December 10, 2023 Author Share Posted December 10, 2023 Hi thanks i manage to play with i'm just ignorant of these subtilities Thanks too for the link of your channel i go see the content Quote Link to comment Share on other sites More sharing options...
OldSchoolRetroGamer Posted December 10, 2023 Share Posted December 10, 2023 @Brad_from_the_80s , @MysticSword You both seem to have missed his second post, with some assistance he has played it successfully and asked for the thread to be closed. 🤷♂️ Quote Link to comment Share on other sites More sharing options...
Brad_from_the_80s Posted December 10, 2023 Share Posted December 10, 2023 7 hours ago, OldSchoolRetroGamer said: @Brad_from_the_80s , @MysticSword You both seem to have missed his second post, with some assistance he has played it successfully and asked for the thread to be closed. 🤷♂️ I think I responded at almost the same moment as OP, but problem solved apparently. 1 Quote Link to comment Share on other sites More sharing options...
Mockduck Posted December 10, 2023 Share Posted December 10, 2023 I have had the same issue with all three of the Space Invaders carts I have, issue is a fair number of shots both from me and the enemies simply don't display on the screen. They are there and can hit stuff or me, but they just don't display. Happens maybe one out of five or so shots. Quote Link to comment Share on other sites More sharing options...
Karadoc Posted December 10, 2023 Author Share Posted December 10, 2023 Mine seems working perfectly but the game is though I'm thinking that this game needs an enhanced version with drive gear controller compatibility Quote Link to comment Share on other sites More sharing options...
Sean_1970 Posted December 10, 2023 Share Posted December 10, 2023 5 minutes ago, Karadoc said: Mine seems working perfectly but the game is though I'm thinking that this game needs an enhanced version with drive gear controller compatibility Space Invaders with a paddle controller? Hadn’t occurred to me, but could be a winner! Over 100 gane modes seems waaaaayyyy over the top for this cart - I mean that has to be the record, right? Quote Link to comment Share on other sites More sharing options...
Brad_from_the_80s Posted December 10, 2023 Share Posted December 10, 2023 24 minutes ago, Mockduck said: I have had the same issue with all three of the Space Invaders carts I have, issue is a fair number of shots both from me and the enemies simply don't display on the screen. They are there and can hit stuff or me, but they just don't display. Happens maybe one out of five or so shots. Think this has been reported elsewhere, but was also suggested to be sure your display is in game mode or has post-processing features like motion smoothing turned off if you're using a modern TV. I'm not sure there is any issue with Space Invaders beyond that, as I have not seen this on my NTSC version. Quote Link to comment Share on other sites More sharing options...
Karadoc Posted December 10, 2023 Author Share Posted December 10, 2023 12 hours ago, OldSchoolRetroGamer said: @Brad_from_the_80s , @MysticSword You both seem to have missed his second post, with some assistance he has played it successfully and asked for the thread to be closed. 🤷♂️ cause i'm a new member my post need validation and you see them later it's create a bit confusion on the thread 2 Quote Link to comment Share on other sites More sharing options...
OldSchoolRetroGamer Posted December 10, 2023 Share Posted December 10, 2023 Ah ok then...........😁 2 Quote Link to comment Share on other sites More sharing options...
