High Score Enabled Centipede almost there, Disk I/O issue though.
I've converted Centipede to be High Score Enabled, but there's a slight issue where the disk reads and writes fail.
Is this because of re-vectored VVBLKI which is clobbering POKEY state?
I've attached a disk image here: Centipede.atr
And the relevant source code is here:
https://github.com/FujiNetWIFI/fujinet-high-scores/tree/main/atari-game-ports/centipede
I've also attached a listing from the assembly: Centipede.lst
-Thom
EDIT: Jump to second half of posting.
The re-vectored VVBLKI jumps into the original SYSVBV.
It also checks right at its beginning the value of $81. If it is !=#$00 then it jumps directly into SYSVBV.
Save the value in $81, set it to 1, read or write the sector(s) and restore $81 to its original value.
Then you will know if the VVBLKI is your problem.
Below is the start of the re-vectored VVBLKI:
    A9A9: D8                CLD
    A9AA: A9 00             LDA #$00
    A9AC: 8D 08 D2          STA AUDCTL
    A9AF: A9 03             LDA #$03
    A9B1: 8D 0F D2          STA SKCTL
    A9B4: 8D 32 02          STA SSKCTL
    A9B7: A5 81             LDA $81	; check $81
    A9B9: D0 07             BNE $A9C2	; !=0?
    A9BB: A5 90             LDA $90
    A9BD: F0 06             BEQ $A9C5
    A9BF: 4C CC A9          JMP $A9CC
    A9C2: 4C 73 AA          JMP $AA73
    AA73: 4C 5F E4          JMP SYSVBV	; original VVBLKI
2nd half:
After I posted, my view fell to the writes to SKCTL and SSKCTL. These are the serial control register and its page 2 shadow.
If the VBI manipulates these during SIO, it will certainly fail.
Therefore changing $81 takes effect too late in the VBI.
Try this instead:
	LDA RTCLOK+2
wait1:
	CMP RTCLOK+2
	BEQ wait1	; wait for end of current/next VBI
	LDA VVBLKI
	PHA
	LDA VVBLKI+1
	PHA
	LDA SYSVBV+1
	STA VVBLKI
	LDA SYSVBV+2
	STA VVBLKI+1
; do your I/O
	LDA RTCLOK+2
wait2:
	CMP RTCLOK+2
	BEQ wait2	; wait for end of current/next VBI
	PLA
	STA VVBLKI+1
	PLA
	STA VVBLKI
    A9A9: D8                CLD
    A9BB: A5 90             LDA $90
That is indeed part of it, the reads no longer hang, but they also don't load the table in. 😕
Two errors:
1. Either you were faster than my edit or you missed "EDIT: Jump to second half of posting." in above posting.
2. With my shortened disk I/O routine you must JSR DSKINV instead of JSR SIOV because otherwise the DCB will not be populated completely.
Two errors:
1. I was, sorry. :)
2. I changed it back to use SIOV (and populated DSTATS and DBYT) as part of trying to debug.
Yes, with your changes above, it does indeed work. Thank you so much.
-Thom
