drunkeneye Posted December 23, 2023 Share Posted December 23, 2023 I would like to define four players in Mad Pascal. Usually I'd do something like type TPlayer = record Name: TString; Strength: Byte; end; var players: array[0..3] of ^TPlayer; begin; // not interesting for i:=0 to High(players) do begin GetMem(players[i], sizeof(TPlayer)); players[0].strength := 30; end; However, the simple assignment compiles into 3A68:AD 79 41 LDA $4179 3A6B:85 92 STA $92 ;MEOLFLG 3A6D:AD 7A 41 LDA $417A 3A70:18 CLC 3A71:69 00 ADC #$00 3A73:85 93 STA $93 3A75:A0 00 LDY #$00 3A77:B1 92 LDA ($92),Y ;MEOLFLG 3A79:85 84 STA $84 ;VNTD 3A7B:C8 INY 3A7C:B1 92 LDA ($92),Y ;MEOLFLG 3A7E:85 85 STA $85 ;VNTD+1 3A80:A0 42 LDY #$42 3A82:A9 1E LDA #$1E 3A84:91 84 STA ($84),Y ;VNTD which looks like a complete overkill for a simple assignment. Am i missing something, like a nice compiler optimization flag? Or am i doing it wrong? I think in assembler I could get it in 5-6 instructions. I'd love to see MadPascal to do something similar. But my Pascal got rusty and I hate Pointers. Thanks for any help! Quote Link to comment Share on other sites More sharing options...
dmsc Posted December 23, 2023 Share Posted December 23, 2023 Hi! 2 hours ago, drunkeneye said: I would like to define four players in Mad Pascal. Usually I'd do something like type TPlayer = record Name: TString; Strength: Byte; end; var players: array[0..3] of ^TPlayer; begin; // not interesting for i:=0 to High(players) do begin GetMem(players[i], sizeof(TPlayer)); players[0].strength := 30; end; Using dynamic memory in a 6502 is never going to be fast - you are allocating memory at runtime and storing the address into an array, so the compiler has no way of knowing the address of your variable. If you know which index you are accessing, it is better if you initialize your array with static pointers, then the compiler will generate optimal code: type TPlayer = record Name: TString; Strength: Byte; end; var P0, P1, P2, P3: TPlayer; players: array[0..3] of ^TPlayer; begin; players[0] := @P0; players[1] := @P1; players[2] := @P2; players[3] := @P3; P0.Strength := 30; end. And try to use functions to access the pointers - it is also faster if you access many elements of the array: type TPlayer = record Name: TString; Strength: Byte; end; PlayerPtr = ^TPlayer; var players: array[0..3] of ^TPlayer; i : byte; procedure initPlayer(n : Byte); var p: PlayerPtr; begin GetMem(p, sizeof(TPlayer)); p^.Strength := 30; (* ...... *) players[n] := p; end; begin; for i:=0 to High(players) do initPlayer( i ); end. Have Fun! 4 Quote Link to comment Share on other sites More sharing options...
drunkeneye Posted December 24, 2023 Author Share Posted December 24, 2023 Thank you very much! I realize that i should not use anything dynamic to get more compact code. So i opted now create the four variables using var and then use a simple case switch to set currentPlayer := @player1/2/3/4. this way i can use currentPlayer via currentPlayer^.strength := 30; and the code seems efficient. However-- I cannot use the strings like i want to (in blibs): CRT_WriteCentered(2, p^.name); yields Error: Incompatible types: got "UNTYPED" expected "STRING" So i am still missing something. Can anyone help why this doesnt work with strings, but does so with e.g. bytes? Quote Link to comment Share on other sites More sharing options...
