Achievement Unlocked: TRS-80 Model 1
Hey Folks,
Just got a TRS-80 Model 1, and Expansion Interface to match.
ABLVV857fHl561uMob9MRk8zfVOkG_3na17IkcN2Jqa36ofsAnae4qDQA08lDtUnkr1nXQ4EjzNZOlj--p2UAm5-cWtyrwERr-xZDgL-svaEKXx9wyLa9T_dh1IEUnHDW4nXuPLDf3E8tuFOtfg3Xcw4G7pXDDFQMQ57bQuam5x7RKLKvM8OSsNmdQcVyXSmMQfFICUbFYWCxG9U2KfPrAFm3ZNjPIM3-31y-J1XDjhRu7NXvFE1OvsyrouA6fnVFr4xGNem00hcarAIrOPiG-BzTMXbof6lIbiFSjTQXGyFLwg3hVhkhs6cx878YSgLA5GAQ59lGcMO3WbiDbW3iYzqgodQB8PY1ad6qK-PQyV4G03hULt-fF_S3_WRhaXPufcvds1kD7cFf6Rr8SEV98xdz-rbrb5qgV-6WnxuK7K0PPblMT1fXbyfiJJH3EGsuPmNNK7vkM0K_wWqIOb3y048cdXoVEBFeAom4kZgrF9fNZcsva1OEBo3vTJRawHNdwlMQ6ebgX7Jc6gZJNmw2LhVqRxMkOKHjJbadUA946wDbMrhocrfAh_HTUnzDpj7C9brOzybrg72jNuHZFFwAwUHuK9BsbbPPPIBO_g_KZ_DPv1DcQGS5D8jJiwqjZlzj_BIv4u00WhPGjwR7hr76G3KblKW89iu1iquXuTmU05vPjWbn5GwhbF1zpPoR6tz_UyZopdZrk0kwqMq2sW2ohTobxhb0eSFOst9zpfZz3EblWnqzww1N8atAyRmD0DtH4d1bOZm8JpSidoxATqdl7CgjWEkWK4xjd-29nI1l4W6kGSPx-gGUHZt7wVkdvec14hgtUCtrrPDt1yYdljYm0RdzsRzb8U0A-rJbQZWLq7k3QzUyZ5lHhqziSHvOZk=w1375-h1031-s-no-gm?authuser=0
(This was when I got it. It's much cleaner now)
Both parts were dirty, but mostly cleaned up OK. The Model 1 has two dead keys, and one dodgy key, but otherwise seems to boot fine. Unfortunately I have no way (yet) to test the Expansion Interface, as I only got one PSU with the two units.
I'll desolder the malfunctioning keys and see if I can resurrect them shortly. I may need to replace that evil keyboard ribbon cable while I'm at it. We shall see.
Open to suggestions on a solution for the second PSU. The first one seems remarkably simple. A 16v transformer and a pair of diodes...
Can't wait to get the expander working.
Cheers!
Chesh
https://forums.atariage.com/topic/358823-achievement-unlocked-trs-80-model-1/
Yeah there's space in there for a pair of 110v PSU. (Found the cavity while cleaning it up). The Aussie PSU seems to be about 75% bigger than the US one so mine was plugged into the expansion, but wasn't in the expansion. There's definitely room enough I can hide something in there.
I was looking at toroidals from Altronics. Not sure the minimum voltage the units will run from, but if they will support ~14V on the DC line, I can power both units from the one toroidal and hide the gubbins in the Expansion Interface. That way I could run both systems from the one wall connection.
I'd want to build something with some safety features not found in the stock PSU, such as a fuse, and an on / off switch. I don't really want to case hack it, but it's already in rough shape. I will need to make a decision on that.
Chesh
