Okay here is a Directory program you can type and run from BASIC or XB.
I suggest using a file name of "DIR" or "!DIR".  The second one usually keeps it at the top of your listings.
100 CALL CLEAR
110 INPUT "DISK DRIVE (1-3):":D
120 D=INT(D)
130 IF(D<1)+(D>3)THEN 110
140 OPEN #1:"DSK"&STR$(D)&".",INPUT ,RELATIVE,INTERNAL
150 INPUT #1:A$,FT,FS,RL
160 DISPLAY :"DSK";STR$(D);".";A$;
170 DISPLAY TAB(17);"SEC:";TAB(21);SEG$("    ",1,4-LEN(STR$(FS+2)))&STR$(FS+2)
180 DISPLAY :"AVAILABLE:";STR$(RL);TAB(17);"USED:";STR$(FS-RL)
190 DISPLAY :"FILENAME   SIZE TYPE   P":"---------- ---- ------ -";
200 INPUT #1:A$,FT,FS,RL
210 IF LEN(A$)=0 THEN 290
220 DISPLAY :A$;TAB(12);SEG$("    ",1,4-LEN(STR$(FS)))&STR$(FS);
230 DISPLAY TAB(17);SEG$("D/FD/VI/FI/VPGM",(ABS(FT)-1)*3+1,3);
240 IF ABS(FT)=5 THEN 260
250 DISPLAY SEG$("   ",1,3-LEN(STR$(RL)))&STR$(RL);
260 IF FT>0 THEN 200
270 DISPLAY TAB(24);"Y";
280 GOTO 200
290 CLOSE #1
300 END
Line 170 and 220 have 4 spaces between the quotes in the SEG$.
Line 190 has 10 minuses, space, 4 minuses, space, 6 minuses, space, and 1 minus in the DISPLAY.
Line 250 has 3 spaces between the quotes in the SEG$.
... enjoy ...
  • Like 5
https://forums.atariage.com/topic/359289-yet-another-diretory-program-for-basxb/
"D/FD/VI/FI/VPGM"
What do your file type acronyms mean?  Is D "DISPLAY VARIABLE" ?  And why is there a V on VPGM?
Mostly just curious... Everyone comes at this machine from a different perspective.
There is an additional file type not covered here, but since this is restricted to DSK1-3, we don't kneed to worry about sub-directories.
