Store player graphic data label as const?
Gemintronic
I'm trying to store the start of a player sprite data as a const.
Something like this works:
 const _id_spcfsh = <playerL0363_1
But, the trouble is you need to manually dig into the output .asm source and find the correct label.
Is there any way to do this with a player sprite label like this?
p1_2
 rem Space Fish
 player1:
 %00000000
 %00000100
 %00000110
 %00001100
 %01111000
 %10011101
 %10011110
 %01111011
 %00110010
 %00001000
 %00000110
 %00000000
end
I'd suggest using the technique used in 1942.  Essentially, using 'data' statements to label the data, and setting the pointer manually.
For defining the sprite graphics data:
;--- The following macro helps keep sprite graphics contained within a page.
    asm
      MAC PAD_BB_SPRITE_DATA
.SPRITE_HEIGHT  SET {1}
      if	(<*) > (<(*+.SPRITE_HEIGHT))
      repeat	($100-<*)
      .byte	0
      repend
      endif
      if (<*) < 90
	   repeat (90-<*)
	   .byte 0
	   repend
	   endif
   ENDM
;--  Sprite Graphics Data
    asm
    PAD_BB_SPRITE_DATA 5
end
  data _Small_Plane_down
   %00011000
   %01111110
   %01111110
   %00011000
   %00111100
   0
end
And then for setting the graphics:
;--- create constants to contain address of _Small_Plane_down data
    const _Small_Plane_high     = >_Small_Plane_down
    const _Small_Plane_low      = <_Small_Plane_down
;-- IN the code, where you want to set the player sprite to use the _Small_Plane_down graphics DO:
    player1pointerlo = _Small_Plane_low
    player1pointerhi = _Small_Plane_high
CAVEAT:  This code is for the multisprite kernel, but it should work in the standard kernel.  I'm not sure if the PAD_BB_SPRITE_DATA macro needs to be reworked for that kernel or not.   Let me know if things don't work... and I can fiddle around to get it to work.
I suspected as much.  Thank you @splendidnut
While I was scrolling through the bB generated asm I tried copping off of the generated sprite data sections.  Looks like it's doing something similar.
 asm
vp_id_1
    .byte  %11111111
    .byte  %11000101
    .byte  %10100101
    .byte  %10011001
    .byte  %11011011
    .byte  %10111001
    .byte  %10111101
    .byte  %11000111
    .byte  %10111001
    .byte  %10101001
    .byte  %10010001
    .byte  %11111111
 if (<*) > (<(*+11))
    repeat ($100-<*)
    .byte 0
    repend
    endif
 if (<*) < 90
    repeat (90-<*)
    .byte 0
    repend
    endif
end
