dgrams2000 Posted January 13 Share Posted January 13 So, I am doing some asm, up to the point of putting my sprite/ship on the screen at the bottom, like in space invaders. I can get it to move left, right... but I can't for the life of me figure out how to figure out the screen limits for the ship.. and per my code, my ship is stopping at weird points on the screen. The more I tweak it, I get things like fluttering sprites... then I adjust things like the height of my sprite through the drawing of my bitmap loop. (Its 8, with a 9th row of blank) but sometimes I make the drawing loop 8, sometimes 9, to get it to move smooth. Not sure what is affecting it. I get that coding on the 2600 is a challenge.. but what is the best way to simplify it for us Newbies that are trying to understand, but need a little more explanation with things like horizontal movement... Are other retro consoles this challenging? C64/Atari400/800/nes, etc.. 2024-01-13 10-59-51.mp4 Quote Link to comment https://forums.atariage.com/topic/359556-newbie-trying-to-figure-out-horizontal-movement-like-a-space-invaders-baseship/ Share on other sites More sharing options...
+splendidnut Posted January 14 Share Posted January 14 8 hours ago, dgrams2000 said: Are other retro consoles this challenging? Not that I know of. The 2600 method of horizontal positioning is very unique. Without seeing any code, it's hard to make suggestions. Quote Link to comment https://forums.atariage.com/topic/359556-newbie-trying-to-figure-out-horizontal-movement-like-a-space-invaders-baseship/#findComment-5388167 Share on other sites More sharing options...
+bent_pin Posted January 14 Share Posted January 14 As you really don't have enough of the game to give away the farm yet, consider posting your code for better help. Quote Link to comment https://forums.atariage.com/topic/359556-newbie-trying-to-figure-out-horizontal-movement-like-a-space-invaders-baseship/#findComment-5388225 Share on other sites More sharing options...
dgrams2000 Posted January 14 Author Share Posted January 14 processor 6502 ; Default stuff include "vcs.h" ; Default stuff include "macro.h" ; Default stuff ;###################Cleanup tasks & variables################ seg.u Variables org $80 Player0XPos byte ; sprite X coordinate seg Code org $F000 reset ; Clear RAM and all TIA registers ldx #0 lda #0 Clear sta 0,x inx bne Clear BACKCOLOR = $94 ; define a symbol to represent a TIA color value (NTSC) $82 is Drk blue lda #$C2 ; greenw playfield color sta COLUPF ; sets color value to PF lda #$62 ;color purple sta COLUP0 ;set color to player 0 lda #39 sta Player0XPos ; initialize player X coordinate ;################END Cleanup Tasks and variables################# ;##################PLAYFIELD REFLECT OPTION############## reflect: ldx #%00000001 ; CTRLPF register (D0 is the reflect flag) stx CTRLPF ;##################### End PLAYFIELD REFLECT OPTION ##### ;###########SET BACKGROUND#################### background: lda #BACKCOLOR ; load the value from the symbol 'blue' into (a) sta COLUBK ; store (a) into the TIA background color register ;############END BACKGROUND################### ;#########DRAW THAT SCREEN!################### StartFrame: ; start of new frame @ top of screen (Runs WYSYNC 3 times) ldx #%00000000 stx PF0 stx PF1 stx PF2 lda #2 sta VBLANK ; turn VBLANK on sta VSYNC ; turn VSYNC on REPEAT 3 sta WSYNC ; three VSYNC scanlines REPEND lda #0 sta VSYNC ; turn VSYNC off ; start of vertical blank processing ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; Set player horizontal position while we are in the VBLANK ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; lda Player0XPos ; load register A with desired X position and #$7F ; same as AND 01111111, forces bit 7 to zero ; keeping the value inside A always positive sec ; set carry flag before subtraction sta WSYNC ; wait for next scanline sta HMCLR ; clear old horizontal position values DivideLoop: sbc #15 ; Subtract 15 from A bcs DivideLoop ; loop while carry flag is still set eor #7 ; adjust the remainder in A between -8 and 7 asl ; shift left by 4, as HMP0 uses only 4 bits asl asl asl sta HMP0 ; set fine position value sta RESP0 ; reset rough position sta WSYNC ; wait for next scanline sta HMOVE ; apply the fine position offset ;-----------END OF 3 VSYNC LINES Now draw VERTICAL BLANK (37-2 Lines) REPEAT 35 sta WSYNC REPEND lda #0 sta VBLANK ; turn VBLANK off ;----------------------------End Of Top 'Blank' Areas------------------------------ ;---------------------DRAW SCREEN ROUTINE - draw 192 lines----------------------- ;------------------- Initialize X for 192 scanlines------------------------------ REPEAT 184 sta WSYNC ; wait for 60 empty scanlines REPEND ldy 9 ; counter to draw 8 rows of bitmap DrawBitmap: lda Player0Bitmap,Y ; load player bitmap slice of data sta GRP0 ; set graphics for player 0 slice lda P0Color,Y ; load player color from lookup table sta COLUP0 ; set color for player 0 slice sta WSYNC ; wait for next scanline dey bne DrawBitmap ; repeat next scanline until finished lda #0 sta GRP0 ; disable P0 bitmap graphics ;----------------------End Player0 Bitmap------------- ldx #%00000000 stx PF0 stx PF1 stx PF2 ; -------------------------------------------END OF PLAYFIELD--------------- ;------------------------- generate 30 scanlines of overscan bottom of screen (no changes needed here)---- ; ldx #0 ; uses loop of 30 times to complete overscan: lda #2 sta VBLANK ; turn on vblank for overscann REPEAT 30 sta WSYNC REPEND CheckP0Left: lda #%01000000 bit SWCHA bne CheckP0Right dec Player0XPos cmp Player0XPos,5 bne CheckP0Right inc Player0XPos CheckP0Right: lda #%10000000 bit SWCHA bne NoInput inc Player0XPos cmp Player0XPos,50 bne NoInput dec Player0XPos skipincrease: skipdecrease: NoInput: ; fallback when no input was performed ldx #%00000000 stx PF0 stx PF1 stx PF2 jmp StartFrame ; frame is completed, branch back up to the 'startFrame' label ;############################## end of screen draw LOOPS BACK TO StartFrame ################## ;########### BITMAPS ########################################################################## ;--------------Player 0 bitmap---------------- ; org $FFE8 Player0Bitmap: .byte %00000000 ; .byte %10000001 ; .byte %01011010 ; .byte %10100101 ; .byte %00011000 ; .byte %00011000 ; .byte %00011000 ; .byte %00011000 ; .byte %00011000 ; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; Lookup table for the player colors ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; P0Color: byte #$00 byte #$62 byte #$56 byte #$44 byte #$44 byte #$44 byte #$44 byte #$44 byte #$44 ;############# END OF BITMAPS ################################################################# ; ---------------------------DEFAULT END OF PROGRAM JUNK ; org $fffa org $FFFC ; set origin to last 6 bytes of 4k rom irq: .word reset ; NMI ($FFFA) (Default stuff) .word reset ; RESET ($FFFC) (Default stuff) .word reset ; IRQ ($FFFE) (Default stuff) Quote Link to comment https://forums.atariage.com/topic/359556-newbie-trying-to-figure-out-horizontal-movement-like-a-space-invaders-baseship/#findComment-5388311 Share on other sites More sharing options...
dgrams2000 Posted January 14 Author Share Posted January 14 10 hours ago, bent_pin said: As you really don't have enough of the game to give away the farm yet, consider posting your code for better help. done. thx Quote Link to comment https://forums.atariage.com/topic/359556-newbie-trying-to-figure-out-horizontal-movement-like-a-space-invaders-baseship/#findComment-5388466 Share on other sites More sharing options...
+bent_pin Posted January 14 Share Posted January 14 You have an extra compare in your left and right positioning adjustments, can you explain the purpose? In the future, please post code as text in code tags: Makes it much easier for those trying to help. Quote Link to comment https://forums.atariage.com/topic/359556-newbie-trying-to-figure-out-horizontal-movement-like-a-space-invaders-baseship/#findComment-5388614 Share on other sites More sharing options...
dgrams2000 Posted January 18 Author Share Posted January 18 On 1/14/2024 at 11:10 AM, bent_pin said: You have an extra compare in your left and right positioning adjustments, can you explain the purpose? In the future, please post code as text in code tags: Makes it much easier for those trying to help. After the joystick position check, the first compare just lowers the value for moving the sprite... The second compare says that if it crosses a certain point, to increase by one, so that it cant keep moving left. (Stops at left side of screen for example.) Quote Link to comment https://forums.atariage.com/topic/359556-newbie-trying-to-figure-out-horizontal-movement-like-a-space-invaders-baseship/#findComment-5391154 Share on other sites More sharing options...
+bent_pin Posted January 18 Share Posted January 18 33 minutes ago, dgrams2000 said: The second compare says that if it crosses a certain point, to increase by one, so that it cant keep moving left. I thought that is what you were trying to do. That is not what you've done, though. cmp Player0XPos,50 ; cmp followed by a memory ZP memory address,offset ; compares what is in the accumulator to what is in the memory address + offset ; same flags as sbc with the same values ; Player0XPos address = $80 ; $80 + 50 = 178 or $B2 ; This instruction compares value in ZP$B2 to value in accumulator ; Value currently in accumulator is bitmask #%10000000 or -128 To compare the Player0XPos to 50, you need to load that value into the accumulator first, then use compare with the immediate value of 50. lda Player0Pos cmp #50 Quote Link to comment https://forums.atariage.com/topic/359556-newbie-trying-to-figure-out-horizontal-movement-like-a-space-invaders-baseship/#findComment-5391175 Share on other sites More sharing options...
dgrams2000 Posted January 18 Author Share Posted January 18 (edited) 47 minutes ago, bent_pin said: I thought that is what you were trying to do. That is not what you've done, though. cmp Player0XPos,50 ; cmp followed by a memory ZP memory address,offset ; compares what is in the accumulator to what is in the memory address + offset ; same flags as sbc with the same values ; Player0XPos address = $80 ; $80 + 50 = 178 or $B2 ; This instruction compares value in ZP$B2 to value in accumulator ; Value currently in accumulator is bitmask #%10000000 or -128 To compare the Player0XPos to 50, you need to load that value into the accumulator first, then use compare with the immediate value of 50. lda Player0Pos cmp #50 CheckP0Left: lda #%01000000 bit SWCHA bne CheckP0Right dec Player0XPos lda Player0XPos cmp #13 bne CheckP0Right inc Player0XPos CheckP0Right: lda #%10000000 bit SWCHA bne NoInput inc Player0XPos lda Player0XPos cmp #124 bne NoInput dec Player0XPos Interesting. That sound like a crucial thing that I did not know about. Looks like that worked. I can now move my ship accurately across the bottom, stopping at certain points. Seems like you just cant plug in any old positions to compare against.. Like in my example above, If I change the left side to CMP #10, My sprite jumps all over moving left and right. If it is CMP #13.. works fine. I am guessing this has something to do with the fine tuning the object in a certain area (-8 to +7 pixels) and that your numbers have to match up somewhere within that. But anyways.. yes, it is working. Thank you for the tip! I will have about a bazillion more questions soon, I am sure. haha Edited January 18 by dgrams2000 Quote Link to comment https://forums.atariage.com/topic/359556-newbie-trying-to-figure-out-horizontal-movement-like-a-space-invaders-baseship/#findComment-5391184 Share on other sites More sharing options...
+bent_pin Posted January 18 Share Posted January 18 17 minutes ago, dgrams2000 said: After the compare is done, should the accumulator get blanked out then? Typically, I begin each operation by loading values into registers. As such, I see no reason in particular to clear values from registers. I usually assume that they've got garbage in them unless I'm intentionally carrying values through as part of an algorithm. Quote Link to comment https://forums.atariage.com/topic/359556-newbie-trying-to-figure-out-horizontal-movement-like-a-space-invaders-baseship/#findComment-5391194 Share on other sites More sharing options...
dgrams2000 Posted January 18 Author Share Posted January 18 2 minutes ago, bent_pin said: Typically, I begin each operation by loading values into registers. As such, I see no reason in particular to clear values from registers. I usually assume that they've got garbage in them unless I'm intentionally carrying values through as part of an algorithm. Makes sense. Quote Link to comment https://forums.atariage.com/topic/359556-newbie-trying-to-figure-out-horizontal-movement-like-a-space-invaders-baseship/#findComment-5391195 Share on other sites More sharing options...
+bent_pin Posted January 18 Share Posted January 18 28 minutes ago, dgrams2000 said: Seems like you just cant plug in any old positions to compare against.. Like in my example above, If I change the left side to CMP #10, My sprite jumps all over moving left and right. If it is CMP #13.. works fine. I am guessing this has something to do with the fine tuning the object in a certain area (-8 to +7 pixels) and that your numbers have to match up somewhere within that. But anyways.. yes, it is working. Thank you for the tip! I will have about a bazillion more questions soon, I am sure. haha That's because of the type of branch that you are using. You are only checking for equality when you should be checking for a range. Try this one on your own. Think of what types of flags can branches that there are. Try just the left edge to begin with. You can use the carry flag and if you subtract a border value from the position value and that subtraction crosses the zero barrier, the carry flag will be cleared. If you get the left side working, check back for a tip on the right side. Quote Link to comment https://forums.atariage.com/topic/359556-newbie-trying-to-figure-out-horizontal-movement-like-a-space-invaders-baseship/#findComment-5391202 Share on other sites More sharing options...
