7800basic Elegant Variable Management Tips
For 7800basic projects that use extra RAM and have a lot of variables to manage, does anyone have any tips on how to make the process easier to manage/maintain?
As things stand now, I might have something like this:
	dim Var1 = $4000
	dim Var2 = $4001 ; 8 bytes
    dim Var3 = $4009
    ; Etc.
In assembly this would be something like:
    ORG $4000
Var1            ds 1
Var2            ds 8
Var3            ds 1
; Etc.
In the latter case, if I wanted to change the number of bytes of Var2, or if I had a reason to change the order of where they are stored in memory, I wouldn't have to recompute the addresses.
Does anyone have a good way of handling this? I don't mind using inline assembly, but I can't just throw in an "ORG $4000" in the middle of 7800basic source without crashing my program.
My first thought would be to use a spreadsheet with the name in one column, length in the next column, a third column to calculate the address based on the address and length of the previous record, and then the 4th column would be the text output ready to be copied over to your project as necessary.
This sounds more like 7800Basic needs to be updated to support allocating variables in extended RAM.  That would make the most sense to do.  I'm not sure how difficult that would be... depends on whether variable allocation is currently tracked by the compiler or not.
It can allocate variables in extended RAM now. One can use dim to assign a variable to any address. I'm just looking for a better way to define the variables in a way so they will auto-increment the address based on storage size like I can do in assembly.
20 hours ago, splendidnut said:
Yeah, it would be cool to see a clever solution... But, if you're willing, you might want to look and see how hard this would be to implement in the compiler.  Implementing it there would be a win for everyone.
I'd be happy to contribute if desired, though since it's a language direction issue, it would be up to Mike as to if or how such a feature would be added. In the meantime I made a quick and dirty script that I will share here in case anyone else would find it useful.
I've made a small Python script to generate variable symbols with the appropriate addresses, which I am sharing here. It supports an optional storage size parameter (1 byte if not specified), and an optional repeat number, which will generate the specified number of symbols of the specified storage size with that name, followed by a numeric suffix.
The script looks for a file named vars.src in the current directory. The first line of the file is the base starting address (e.g. $2200 or $4000, but also could be a name defined in BASIC code). All lines after that are variables to be defined, with optional parameters for the storage size in bytes, and number of iterations for repeating variables.
Running the script will produce the file vars.asm with the specified variables defined at the correct addresses. Additionally, the symbols BASE_ADDRESS and NEXT_VAR are added to the output, corresponding to the starting address supplied in the source file, and the next free address after all variables have been defined, respectively. The generated vars.asm can be included in the 7800basic project with an inline statement.
genvars.py
Here's an example vars.src file:
$4000
CharName 8 16
Race 1 16
Class 1 16
Traits 1 16
Defects 1 16
STR 1 16
DEX 1 16
CON 1 16
INT 1 16
WIS 1 16
CHA 1 16
Luck 1 16
Items 10 16
Gold 2
CurrentMap
CurrentX
CurrentY
This produces the following output in vars.asm:
BASE_ADDRESS = $4000
CharName0 = $4000 + 0
CharName1 = $4000 + 8
CharName2 = $4000 + 16
CharName3 = $4000 + 24
CharName4 = $4000 + 32
CharName5 = $4000 + 40
CharName6 = $4000 + 48
CharName7 = $4000 + 56
CharName8 = $4000 + 64
CharName9 = $4000 + 72
CharName10 = $4000 + 80
CharName11 = $4000 + 88
CharName12 = $4000 + 96
CharName13 = $4000 + 104
CharName14 = $4000 + 112
CharName15 = $4000 + 120
Race0 = $4000 + 128
Race1 = $4000 + 129
Race2 = $4000 + 130
Race3 = $4000 + 131
Race4 = $4000 + 132
Race5 = $4000 + 133
Race6 = $4000 + 134
Race7 = $4000 + 135
Race8 = $4000 + 136
Race9 = $4000 + 137
Race10 = $4000 + 138
Race11 = $4000 + 139
Race12 = $4000 + 140
Race13 = $4000 + 141
Race14 = $4000 + 142
Race15 = $4000 + 143
Class0 = $4000 + 144
Class1 = $4000 + 145
Class2 = $4000 + 146
Class3 = $4000 + 147
Class4 = $4000 + 148
Class5 = $4000 + 149
Class6 = $4000 + 150
Class7 = $4000 + 151
Class8 = $4000 + 152
Class9 = $4000 + 153
Class10 = $4000 + 154
Class11 = $4000 + 155
Class12 = $4000 + 156
Class13 = $4000 + 157
Class14 = $4000 + 158
Class15 = $4000 + 159
Traits0 = $4000 + 160
Traits1 = $4000 + 161
Traits2 = $4000 + 162
Traits3 = $4000 + 163
Traits4 = $4000 + 164
Traits5 = $4000 + 165
Traits6 = $4000 + 166
Traits7 = $4000 + 167
Traits8 = $4000 + 168
Traits9 = $4000 + 169
Traits10 = $4000 + 170
Traits11 = $4000 + 171
Traits12 = $4000 + 172
Traits13 = $4000 + 173
Traits14 = $4000 + 174
Traits15 = $4000 + 175
Defects0 = $4000 + 176
Defects1 = $4000 + 177
Defects2 = $4000 + 178
Defects3 = $4000 + 179
Defects4 = $4000 + 180
Defects5 = $4000 + 181
Defects6 = $4000 + 182
Defects7 = $4000 + 183
Defects8 = $4000 + 184
Defects9 = $4000 + 185
Defects10 = $4000 + 186
Defects11 = $4000 + 187
Defects12 = $4000 + 188
Defects13 = $4000 + 189
Defects14 = $4000 + 190
Defects15 = $4000 + 191
STR0 = $4000 + 192
STR1 = $4000 + 193
STR2 = $4000 + 194
STR3 = $4000 + 195
STR4 = $4000 + 196
STR5 = $4000 + 197
STR6 = $4000 + 198
STR7 = $4000 + 199
STR8 = $4000 + 200
STR9 = $4000 + 201
STR10 = $4000 + 202
STR11 = $4000 + 203
STR12 = $4000 + 204
STR13 = $4000 + 205
STR14 = $4000 + 206
STR15 = $4000 + 207
DEX0 = $4000 + 208
DEX1 = $4000 + 209
DEX2 = $4000 + 210
DEX3 = $4000 + 211
DEX4 = $4000 + 212
DEX5 = $4000 + 213
DEX6 = $4000 + 214
DEX7 = $4000 + 215
DEX8 = $4000 + 216
DEX9 = $4000 + 217
DEX10 = $4000 + 218
DEX11 = $4000 + 219
DEX12 = $4000 + 220
DEX13 = $4000 + 221
DEX14 = $4000 + 222
DEX15 = $4000 + 223
CON0 = $4000 + 224
CON1 = $4000 + 225
CON2 = $4000 + 226
CON3 = $4000 + 227
CON4 = $4000 + 228
CON5 = $4000 + 229
CON6 = $4000 + 230
CON7 = $4000 + 231
CON8 = $4000 + 232
CON9 = $4000 + 233
CON10 = $4000 + 234
CON11 = $4000 + 235
CON12 = $4000 + 236
CON13 = $4000 + 237
CON14 = $4000 + 238
CON15 = $4000 + 239
INT0 = $4000 + 240
INT1 = $4000 + 241
INT2 = $4000 + 242
INT3 = $4000 + 243
INT4 = $4000 + 244
INT5 = $4000 + 245
INT6 = $4000 + 246
INT7 = $4000 + 247
INT8 = $4000 + 248
INT9 = $4000 + 249
INT10 = $4000 + 250
INT11 = $4000 + 251
INT12 = $4000 + 252
INT13 = $4000 + 253
INT14 = $4000 + 254
INT15 = $4000 + 255
WIS0 = $4000 + 256
WIS1 = $4000 + 257
WIS2 = $4000 + 258
WIS3 = $4000 + 259
WIS4 = $4000 + 260
WIS5 = $4000 + 261
WIS6 = $4000 + 262
WIS7 = $4000 + 263
WIS8 = $4000 + 264
WIS9 = $4000 + 265
WIS10 = $4000 + 266
WIS11 = $4000 + 267
WIS12 = $4000 + 268
WIS13 = $4000 + 269
WIS14 = $4000 + 270
WIS15 = $4000 + 271
CHA0 = $4000 + 272
CHA1 = $4000 + 273
CHA2 = $4000 + 274
CHA3 = $4000 + 275
CHA4 = $4000 + 276
CHA5 = $4000 + 277
CHA6 = $4000 + 278
CHA7 = $4000 + 279
CHA8 = $4000 + 280
CHA9 = $4000 + 281
CHA10 = $4000 + 282
CHA11 = $4000 + 283
CHA12 = $4000 + 284
CHA13 = $4000 + 285
CHA14 = $4000 + 286
CHA15 = $4000 + 287
Luck0 = $4000 + 288
Luck1 = $4000 + 289
Luck2 = $4000 + 290
Luck3 = $4000 + 291
Luck4 = $4000 + 292
Luck5 = $4000 + 293
Luck6 = $4000 + 294
Luck7 = $4000 + 295
Luck8 = $4000 + 296
Luck9 = $4000 + 297
Luck10 = $4000 + 298
Luck11 = $4000 + 299
Luck12 = $4000 + 300
Luck13 = $4000 + 301
Luck14 = $4000 + 302
Luck15 = $4000 + 303
Items0 = $4000 + 304
Items1 = $4000 + 314
Items2 = $4000 + 324
Items3 = $4000 + 334
Items4 = $4000 + 344
Items5 = $4000 + 354
Items6 = $4000 + 364
Items7 = $4000 + 374
Items8 = $4000 + 384
Items9 = $4000 + 394
Items10 = $4000 + 404
Items11 = $4000 + 414
Items12 = $4000 + 424
Items13 = $4000 + 434
Items14 = $4000 + 444
Items15 = $4000 + 454
Gold = $4000 + 464
CurrentMap = $4000 + 466
CurrentX = $4000 + 467
CurrentY = $4000 + 468
NEXT_VAR = $4000 + 469
