What does this F18A screen mean?
While trying my cartridge-to-breadboard adapter, I got this screen upon startup:
What does it mean?  The F18A is an original from 2012, not upgraded, in a silver-and-black console.
When I unplugged the adapter the computer started normally.
My adapter is this.  I was using one of those fancy 80-pin IDE cables to connect to a couple of logic gates on the breadboard.
K-R.
K-R.
@matthew180 is the  creator of the F18A and the code, so he should be able to assist.
Thanks for the help.  I downloaded v1.9 and, used the dsk2cf program that came with my NanoPEB to copy the disk image to a CF board.  Got "permissions" errors trying to verify any files in it with TI99-Dir on my WinXP and Win7 systems (hate OSes that don't let you access your own hardware).  The Win98 machine has a CF reader in it with drivers, but I have to make a USB adapter to use it.
Now I'm not sure my console is entirely trustworthy.  I get the green screen again, with flashing letters and symbols, like the "light show" on an old CGA/EGA display when a program crashed.  Or I get a blank screen.
Right now the console is belly-up on my work-table, getting the cartridge port glop-applicator removed.  I've cleaned the fingers on my cartridges, on theory the cartridge-port glop is affecting their operation.
I'll post my results.
K-R.
As others have mentioned, the V1.3 firmware is old and is the original release from 2012.  There have been many updates with the latest being V1.9 (also mentioned).  However, do NOT update if you console is not stable.  At the very least you need a reliable system.  The updater tries really hard to not brick the board, but if you lose power at the wrong time it is possible.  If that happens you will need have it updated via JTAG (we can discuss those options if it comes to that).
When you see that "green screen" (as it has been called), that means (as OLDCS1 mentioned) that the F18A is powered up, the FPGA has loaded its configuration and is operational, but the host computer has not tried to talk to the VDP.  You can basically consider seeing that screen as a way to know that the F18A is working, but your host computer is not working.
Garbage on the screen would suggest that the computer is trying to talk to the VDP, but there is corruption somewhere.
When you are making your own hardware, you need to be careful with the 99/4A cartridge port.  There are some odd signals like the reset circuit that is exposed to the port.  Also, make sure any external devices like the NanoPEB, CF7, Tipi, etc. are using their own external power.  People making expansion devices seem to ignore the power consumption aspect of their project devices, and the 99/4A power supply was only designed to power the motherboard and one cartridge (and I suppose the speech synth).
Thanks for the advice, matthew180.  The update is on hold, for now, with the demise of my Ed/Asm cartridge.  I had removed the board from the case to put a chip clip on it for my logic analyzer.  I checked supply voltages on the port using a Shift838 cartridge-breakout board; all were okay, except for +5V being at 4.8.  While checking the system after the green screen I think I plugged the Ed/Asm board wrong-side-up.  Now it doesn't work.  Blasto, Ext-BASIC, and Disk Manager started up, as does console BASIC.  I'd have gladly traded Blasto for Ed/Asm!
The green screen happened while I was using a cartridge-to-breadboard adapter that I had drawn-up and had boards made.  It worked okay until I connected some ICs to it on the breadboard.  That's when I got the green screen.  Figuring I had broken something, I pulled the adapter from the cartridge port and tried to start the system and got the standard TI boot screen.
The system is run off of an external 3-output supply, a Mean Well RT-65A that puts out +/-5V and +12V.  It's rated for 6 amps on the +5V line, so I power the NanoPEB off of it as well.  Disk Manager was able to read the Compact Flash.  The setup seems to work; I had set the V1.9 upgrade disk image as DSK3 and was able to catalog it to see the upgrade files in it.
I have a FinalGROM to try but it's always been kind of flakey.  The board looks twisted inside the case.
K-R.
Edited by Kchula-Rrit
While looking around Fred Kaal's Web-site, I ran across these Ed-Assem ROM images in the modules page:
 Editor/Assembler II r2
 Editor/Assembler III r2
 Editor/Assembler IV r4
The pages indicate that it is available for a "64K Green Board" "inverted" ROM cartridge "v03c".  i happen to have one of these sitting on my work table.
Anyone tried running running the F18A updater with this program?
K-R.
K-R.
probably work fine
  • 2 weeks later...
Almost...
While I was putting the computer back together, my keyboard cable decided to snap.  I wonder if the F and U keys were a "message"...
A replacement cable has been ordered from the arcadeshopper Web-site.
Thanks for the assistance and encouragement!
K-R.
  • Haha 4
  • Sad 1
