Hi Everyone, my TI console no longer has a working keyboard.  Powers on just fine, comes up with the TI logo screen.  No key works.  It's like the keyboard is completely disconnected.  This is a daily driver.  It hasn't been moved and I love the keyboard actually - opened it up and reseated the cable.  No change.  Still - no key works.  Any ideas on what might cause the failure?  Thank you, Arthur...
https://forums.atariage.com/topic/360510-keyboard-stopped-working-ideas-on-a-fix/
I'd first look at the cable on the TI keyboard where it is soldered to the PCB, that area fails a lot. Then if that is good, I'd change out the 9901 on the TI.
Can't seem to find a 9901.  I did check the keyboard cable and connection to the board - all good.  Sadly, most of the chips are soldered onto the board.  Checked the PCB where the keyboard cable is connected - seems good.  At least the pins tested OK.  No obviously toasted caps or resistors, no smell or other evidence that the magic escaped.  Any other ideas?
Look here.
@aftyde given the price of eBay 99s (depending on your location) a whole 99 is probably not far off the cost point of a chip or keyboard.
With the kb removed, I'd do a momentary key simulation at a "press any key" location to see if the chip responds.
I feel for you. My console did the same thing a few months ago. I replaced the 9901 and all is well. Seems they may be easy to kill. I touched my console during a period of low humidity = static. Sad part is that I knew the conditions called out at the lab at work and then I went home and touched her.
