dabone Posted February 4 Share Posted February 4 After a failed attempt to get HDMI from my 99/4a using a rgb adapter with a RGBtoHDMI, I grabbed one of the brand new TMSdigitizer from C0pperdragon. It looks great, (I had scanlines turned on in the picture.) I've now got digital out for most of my vintage collection now. The TI was the last of the major brand machines I have that I didn't have a adapter for. 1 Quote Link to comment https://forums.atariage.com/topic/360659-anyone-else-tried-the-new-lumacode-adapter/ Share on other sites More sharing options...
+retroclouds Posted February 4 Share Posted February 4 (edited) I found this link. Is that what you are referring to? https://github.com/c0pperdragon/LumaCode/wiki/TMSdigitizer-(for-ColecoVision-and-MSX) And this for installation on the TI-99/4a: https://github.com/c0pperdragon/LumaCode/issues/13#issuecomment-1902838176 Edited February 4 by retroclouds Quote Link to comment https://forums.atariage.com/topic/360659-anyone-else-tried-the-new-lumacode-adapter/#findComment-5403420 Share on other sites More sharing options...
dabone Posted February 4 Author Share Posted February 4 Yep, that's the one. He sells it on tindie. It needs a external RGBtoHDMI adapter, using either his lumacode only board, or a analog board. I've got a c128, Atari 800xl, and now the TI with lumacode adapters. So I just use one external box for all of them (It also works on the composite out of the ZX81 (Timex TS1000 in the USA)) I've been going a bit overboard with converting to digital out in the last year. C64 - HDMI - Vic II Kawari Large - Case mod for rgb and HDMI out C128 - Lumacode - Uses RF output connector C128 RGB - RGB2HDMI - TTL Buffer Board - DB9 on rear of computer. TS1000 (ZX81) - RGB2HDMI - Analog Board, Straight from composite mod. ATARI 800xl - Lumacode - Uses RF output connector TI99/4a - Lumacode - Uses Din Connector, Needs pigtail Apple IIe - RGB2HDMI - Internal Wiring to Motherboard, DB25 connector on rear, 12bit TTL Board Apple IIGS - RGB2HDMI - Internal Wiring to Motherboard, DB25 connector on rear, 12bit TTL Board Amiga 500 - RGB2HDMI - Internal RGB2HDMI board, with HDMI Full size breakout on case bracket Amiga 2000 - RGB2HDMI - Internal RGB2HDMI board, with HDMI Full size breakout on case bracket Coco 3 - RGB2HDMI - External Connector to Analog Board Coco 2 - RGB2HDMI - Internal Connector to Analog Board (Wires hanging out the back) Atari 520STFM - RGB2HDMI - Internal Wiring to Motherboard or interposer board, still haven't figured out getting out of the case, 12bit TTL Board IBM 5150/5160/5162 - RGB2HDMI - DB9 to TTL buffer Board. 1 Quote Link to comment https://forums.atariage.com/topic/360659-anyone-else-tried-the-new-lumacode-adapter/#findComment-5403559 Share on other sites More sharing options...
Gary from OPA Posted February 4 Share Posted February 4 @dabone I wonder how long the shipping is from his tindie site to Canada. Also what rgb2hdmi adapter are you using? Quote Link to comment https://forums.atariage.com/topic/360659-anyone-else-tried-the-new-lumacode-adapter/#findComment-5403570 Share on other sites More sharing options...
dabone Posted February 4 Author Share Posted February 4 Shipping is decently quick to USA, and I've got his adapter, and a couple of analog boards. Quote Link to comment https://forums.atariage.com/topic/360659-anyone-else-tried-the-new-lumacode-adapter/#findComment-5403580 Share on other sites More sharing options...
