nitrohepcat Posted February 5 Share Posted February 5 (edited) My TBA 32K sidecar works fine with my Ti by itself and by speech synthesizer works fine by itself. The two worked together fine for a while, but when I started fiddling with it to add the TIPI, they stopped working together. Now when I plug in the 32K sidecar to the speech synthesizer, the screen is all black and a tone is heard. Suggestions welcome if folks have seen this before. Both still work fine independently. EDIT: It looks like the 32K sidecar was being pushed in a tiny bit too far into the speech synth expansion slot. When I pulled the sidecar out slightly then they worked fine together. Edited February 5 by nitrohepcat solved the problem Quote Link to comment https://forums.atariage.com/topic/360724-32k-sidecar-troubleshooting-solved/ Share on other sites More sharing options...
RickyDean Posted February 5 Share Posted February 5 You might consider getting some adhesive cushions or rubber butttons from , lets say a craft store, and place them on the side of the Synth. to keep the 32k from being pushed in to far. 4 1 Quote Link to comment https://forums.atariage.com/topic/360724-32k-sidecar-troubleshooting-solved/#findComment-5404572 Share on other sites More sharing options...
