Jamma PCB/sync problems
RockFox
Hello all! I have a Neo Geo Converstion that I have been working on for ages. First the monitor had problems which cost $125 to fix, now it appears as if the Sync on the PCB board may be bad.. does anyone(particularly in the Denver Metro Area) have a Jamma board I can borrow or even buy cheap so I can test this monitor and see if the repair actually worked?
Thanks everyone! :)
RockFox
Before you go too far...
Try switching the sync wires around. Some monitors, esp. the older ones, only need 1 of the 2 syncs, and others like the syncs tied together. I would experiment. Also, I am assuming its a fairly new monitor, but.....
Make sure there is not a switch for positive or negative sync. I have seen those be culprit before...
HTH,
Cassidy
