Ok, Apparently I'm a bit rusty... Need help with scrolling issue please. :P
Hello all!
So I'm working on a vertical scroller, where the scrolling is constant, and not controlled by the player.
I'm using the same scrolling engine that I used for ReZolve, which worked well at 16 scanlines per zone.
However, this game is 8 scanlines per zone, and I'm getting corruption of the bottom zone (same reason why the bottom zone in PMC 40th doesn't bother with adapting the zone size).
I think I'm running out of CPU time somewhere, but I'm not even taking into account background color yet (which I need to do eventually).  The DLIs just change the origin of the Character Base address to match the size of the zone.
Here are the zone definitions:
;	THIS IS THE DISPLAY LIST LIST FOR THE VIDEO GAME PORTION.  THIS WILL BE DROPPED INTO RAM.
DLLISTPAL
	.byte $0F,>(NULDLST),<(NULDLST)				;25 ADDITIONAL BLANK LINES FOR PAL
	.byte $08,>(NULDLST),<(NULDLST)
DLLISTNTSC
	.byte $09,>(NULDLST),<(NULDLST)				;10 BLANK LINES
	.byte $05,>(NULDLST),<(NULDLST)				;6 BLANK LINES			NTSC/PAL
	.byte $47,>(DLIST00),<(DLIST00)				;PF ZONE 00 - 8 LINES	$06/$0C SCORE LINE
	.byte $01,>(NULDLST),<(NULDLST)				;2 BLANK LINES			$09/$0F SEPARATOR
	.byte $40,>(DLIST01),<(DLIST01)				;PF ZONE 01 - 1 LINE	$0C/$12 (FOR SCROLLING)
	.byte $47,>(DLIST02),<(DLIST02)				;PF ZONE 02 - 8 LINES	$0F/$15
	.byte $47,>(DLIST03),<(DLIST03)				;PF ZONE 03 - 8 LINES	$12/$18
	.byte $47,>(DLIST04),<(DLIST04)				;PF ZONE 04 - 8 LINES	$15/$1B
	.byte $47,>(DLIST05),<(DLIST05)				;PF ZONE 05 - 8 LINES	$18/$1E
	.byte $47,>(DLIST06),<(DLIST06)				;PF ZONE 06 - 8 LINES	$1B/$21
	.byte $47,>(DLIST07),<(DLIST07)				;PF ZONE 07 - 8 LINES	$1E/$24
	.byte $47,>(DLIST08),<(DLIST08)				;PF ZONE 08 - 8 LINES	$21/$27
	.byte $47,>(DLIST09),<(DLIST09)				;PF ZONE 09 - 8 LINES	$24/$2A
	.byte $47,>(DLIST10),<(DLIST10)				;PF ZONE 10 - 8 LINES	$27/$2D
	.byte $47,>(DLIST11),<(DLIST11)				;PF ZONE 11 - 8 LINES	$2A/$30
	.byte $47,>(DLIST12),<(DLIST12)				;PF ZONE 12 - 8 LINES	$2D/$33
	.byte $47,>(DLIST13),<(DLIST13)				;PF ZONE 13 - 8 LINES	$30/$36
	.byte $47,>(DLIST14),<(DLIST14)				;PF ZONE 14 - 8 LINES	$33/$39
	.byte $47,>(DLIST15),<(DLIST15)				;PF ZONE 15 - 8 LINES	$36/$3C
	.byte $47,>(DLIST16),<(DLIST16)				;PF ZONE 16 - 8 LINES	$39/$3F
	.byte $47,>(DLIST17),<(DLIST17)				;PF ZONE 17 - 8 LINES	$3C/$42
	.byte $47,>(DLIST18),<(DLIST18)				;PF ZONE 18 - 8 LINES	$3F/$45
	.byte $47,>(DLIST19),<(DLIST19)				;PF ZONE 19 - 8 LINES	$42/$48
	.byte $47,>(DLIST20),<(DLIST20)				;PF ZONE 20 - 8 LINES	$45/$4B
	.byte $47,>(DLIST21),<(DLIST21)				;PF ZONE 21 - 8 LINES	$48/$4E
	.byte $47,>(DLIST22),<(DLIST22)				;PF ZONE 22 - 8 LINES	$4B/$51
	.byte $47,>(DLIST23),<(DLIST23)				;PF ZONE 23 - 8 LINES	$4E/$54
	.byte $47,>(DLIST24),<(DLIST24)				;PF ZONE 24 - 8 LINES	$51/$57
	.byte $47,>(DLIST25),<(DLIST25)				;PF ZONE 25 - 8 LINES	$54/$5A
	.byte $C7,>(DLIST26),<(DLIST26)				;PF ZONE 26 - 8 LINES	$57/$5D (FOR SCROLLING) (INTERRUPT)
	.byte $85,>(NULDLST),<(NULDLST)				;6 BLANK LINES (INTERRUPT)
DLLENDNTSC
DLLENDPAL
Here is the DLI routine:
;	KERNAL - MAINTAIN THE ON-SCREEN DISPLAY
DLI
	PHA											;STACK REGISTERS
	CLD
	LDA DLIFLG
	BMI DLITOP
	JMP DLIBOT
DLITOP
	LDA MODCHBASE								;ONLY SHOW THE CORRECT NUMBER OF SCANLINES IN THE BOTTOM ZONE
	STA CHRBASE									;INSTALL THE DIFFERENCE IN THE ZONE HEIGHT
	INC DLIFLG
	PLA
	RTI
DLIBOT
	LDA #>(GAMEFONT)
	STA CHRBASE									;INSTALL THE CHARACTERS BACK TO NORMAL
	LDA #$FF
	STA DLIFLG									;RESET DLI FLAG TO GO BACK TO THE TOP
	INC RTLOCAL+1								;INCREMENT CLOCK
	BNE DLIBOTROUTINES
	INC RTLOCAL
DLIBOTROUTINES
	TXA
	PHA
	TYA
	PHA
	JSR LOADER									;LOAD UP NEXT FRAME
	JSR TUNER									;DO TUNES
	JSR RAND									;UPDATE RANDOM NUMBER
	PLA											;UNSTACK AND LEAVE
	TAY
	PLA
	TAX
	PLA											;THIS IS WHERE MOST DLI'S LEAVE
NULLRTI
	RTI
Here is the scroll routine - PLEASE NOTE - I'm not even moving the screen addresses down once the 8 scanline limit is reached yet...  Just trying to do this one step at a time...
;	SCROLLSCRN - DOES THE ACTUAL UPDATING OF THE DL TO SCROLL THE SCREEN
;	INPUT: LEVEL (0-5), 6 FOR TITLE SCREEN, 7 FOR 'GAME OVER' SCREEN
;	OUTPUT: NONE
;	USES: A, X, Y, LDRTEMP2, LDRTEMP3, LDRTEMP4, LDRTEMP5
SCROLLSCRN
	LDA NOSCROLL
	BNE SSSTART								;THIS IS FOR TITLE SCREENS AND ANIMATION SCREENS
	LDA RTLOCAL+1;;;;;;;;;;;;;;;;;;;;;;;
	AND #$0F	;;;;;;;;;;;;;;;;;;;;;;;;  I'M DOING THIS TO SLOW DOWN THE SCROLL SO I CAN WATCH WHAT'S HAPPENING...
	BNE SSSTART;;;;;;;;;;;;;;;;;;;;;;;;;
	INC WINDOWOFFSET
SSSTART
	LDA WINDOWOFFSET
	CMP #$08
	BNE SSUPDATEZONES
	LDA #$00
	STA WINDOWOFFSET
	JMP SSUPDATEZONES;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
SSMOVEZONES
	;THIS IS WHERE THE SCREEN ADDRESSES FOR EACH ZONE WILL GET MOVED (AND THE 'JMP' ABOVE WILL GET REMOVED)
SSUPDATEZONES
	LDY TVTYPE									;GET THE INDEX INTO THE DL BY TV TYPE
	LDA TOPDL,Y
	TAX											;X = DL INDEX OF TOP OF WINDOW ZONE SIZE
	LDA DLL,X
	AND #$F8
	ORA WINDOWOFFSET
	STA DLL,X
	SEC											;COMPUTE BOTTOM DIFFERENCE ZONE SIZE FOR WINDOW
	LDA #$07
	SBC WINDOWOFFSET
	STA LDRTEMP0
	CLC
	LDA BOTDL,Y
	TAX											;X = DL INDEX OF BOTTOM OF WINDOW ZONE SIZE
	LDA DLL,X
	AND #$F8
	ORA LDRTEMP0
	STA DLL,X
	LDA #>(GAMEFONT)							;'MODCHBASE' GETS USED IN THE DLI (TOP WINDOW)
	CLC											; IT TELLS WHAT PAGE TO START THE CHARACTER GRAPHIC
	ADC WINDOWOFFSET							; DEFINITIONS SO WE MAKE SURE WE ONLY SHOW THE CORRECT
	STA MODCHBASE								; PORTION
	RTS
;	THE DISPLAY LISTS TO USE WHEN SCROLLING (FIRST BYTE = NTSC, SECOND = PAL)
TOPDL
	.BYTE $0C,$12
BOTDL
	.BYTE $57,$5D
So this is what I'm seeing at the bottom...
Those are supposed to be readable characters, albeit 4 scanlines high.
Again, this seems to work fine in ReZolve, which is 16 scanline zones instead of 8 here.
Any ideas?
Thanks guys!
Bob
Should be .byte $27
6 hours ago, playsoft said:
It looks good to me. I built a quick test program and it is working correctly. I don't think I made any changes (other than to adapt it to ca65) although I hardcoded it for NTSC only.
Thank you!  I'll take a look at this as well, and see if I'm doing anything different :)
2 hours ago, RevEng said:
Are you sure the object in that last zone is in the right mode, and has a proper terminator?
Thank you :) the game copies the DL to all zones the same (and then updated the screen zone addresses for each zone), and I double-checked the ending bytes (it's the same routine I've used in most of my games)...  and it looks fine.  Thanks for making take another look to confirm; every suggestion helps and removes possibilities.
Ok, so I know what I was doing wrong, and it actually didn't have anything to do with what I had set up (I had set it up correctly - and thank you @Eagle, @playsoft, and @RevEng for giving insight).
I had too many objects in each DL.  This is what I had for each DL:
DLIST
	.byte <(SCRZN00),$60,>(SCRZN00),$80+$0C,#LEFTSIDE 	;SCREEN TILES
	.byte <(STAMPS),$00+$1F,>(STAMPS),#OFFSCRN			;ENEMY SHOT 1 / PLAYER 1 SHOT
	.byte <(STAMPS),$00+$1F,>(STAMPS),#OFFSCRN			;ENEMY SHOT 2 / PLAYER 2 SHOT
	.byte <(STAMPS),$00+$1F,>(STAMPS),#OFFSCRN			;ENEMY SHOT 3
	.byte <(STAMPS),$00+$1F,>(STAMPS),#OFFSCRN			;ENEMY SHOT 4
	.byte <(STAMPS),$00+$1F,>(STAMPS),#OFFSCRN			;ENEMY SHOT 5
	.byte <(STAMPS),$00+$1F,>(STAMPS),#OFFSCRN			;ENEMY SHOT 6
	.byte <(STAMPS),$00+$1F,>(STAMPS),#OFFSCRN			;ENEMY SHOT 7
	.byte <(STAMPS),$00+$1C,>(STAMPS),#OFFSCRN			;ENEMY 1 / PLAYER 1
	.byte <(STAMPS),$00+$1C,>(STAMPS),#OFFSCRN			;ENEMY 2 / PLAYER 2
	.byte <(STAMPS),$00+$1C,>(STAMPS),#OFFSCRN			;ENEMY 3
	.byte <(STAMPS),$00+$1C,>(STAMPS),#OFFSCRN			;ENEMY 4
	.byte <(STAMPS),$00+$1C,>(STAMPS),#OFFSCRN			;ENEMY 5
	.byte <(STAMPS),$00+$1C,>(STAMPS),#OFFSCRN			;ENEMY 6
	.byte <(STAMPS),$00+$1C,>(STAMPS),#OFFSCRN			;ENEMY 7
	.byte <(STAMPS),$00+$1C,>(STAMPS),#OFFSCRN			;ENEMY 8
	.byte $00,$00
DLISTEND
Once I removed everything but the Screen Tiles line (the first line), it scrolled correctly.  It seems I ran out of 'time' in each zone.
So now I just need to see how many objects I can get in each zone before it all goes haywire. :)
Thanks again!
Oof.
Three '$1C'-Wide objects and two '$1F'-Wide shots are all there's time for before the scrolling starts to screw up.  That's not enough for what will be going on in this screen. 😕
I need to figure something out here.
Omg looks like at least 427 cycles for DL (maria limit is 400 per line)
Fixed DL it’s not the best idea. I will try to convert my latest sprites procedure to plain asm (no MADS) and share here tomorrow.
Edited by Eagle
Thanks guys!
Yeah, that was just a 'starting point' for me; I took an existing game and made it scroll, as I knew that would be the first thing that needed to be done.
I'll take a look at the DMA masking as well; I need to get back up to speed with everything. It's so true: if you don't use it, you lose it.
I tried my best. You will get idea ;)
If I find more time I will do working example double buffered Display List.
FirstDL 	equ $4000
x_player	equ $70
y_player	equ $71
nr_sprite	equ $72
colorwidth 	equ $73
Sprite_zone	equ $80		;13*2bytes
;First Display List List line should point FirstDL=$4000 for first DL and increasing 128 bytes for every next DL
; but if you need more sprites than you can do 256 bytes step
; 128 bytes DL will give you up to 31 sprites for each line
;DLL	$4F,>FirstLine,<FirstLine
;  		$4F,>[FirstLine+128],<[FirstLine+128]
;  		$4F,>[FirstLine+256],<[FirstLine+256]
;		etc......
Start
;main loop will looks like this
Main
		jsr waitVBlank
		jsr set_first_dl_sprite_zone		;I'm using name First beacuse this was double buffered sprite procedure
;terminates DL on the start
		jsr clear_dl_first
		;bullet1 - pass in x_player y_player nr_sprite colorwidth
		jsr fast_sprite
		;bullet2 - pass in x_player y_player nr_sprite colorwidth
		jsr fast_sprite
		;bullet3 - pass in x_player y_player nr_sprite colorwidth
		jsr fast_sprite
		;etc....
		;enemie1 - pass in x_player y_player nr_sprite colorwidth
		jsr fast_sprite
		;enemie2 - pass in x_player y_player nr_sprite colorwidth
		jsr fast_sprite
		;enemie3 - pass in x_player y_player nr_sprite colorwidth
		jsr fast_sprite
		;etc....
		;maincharacter - pass in x_player y_player nr_sprite colorwidth
		jsr fast_sprite
;terminate DL's
		jsr add_endDl
		jmp Main
fast_sprite
	ldy y_player		 		;zero page
	ldx Y_tab_new,y
	lda nr_sprite  				;zero page - addres in Maria bank - sprite number
	sta (sprite_zone,x)			;LSB
	inc sprite_zone,x
	lda colorwidth				;zero page - color + width
	sta (sprite_zone,x)
	inc sprite_zone,x
	lda tab_y_16,y			;adjust Y in Zone
	sta (sprite_zone,x)		;MSB
	inc sprite_zone,x
	lda x_player			;zero page - x position
	sta (sprite_zone,x)
	inc sprite_zone,x
; bottom of the sprite
	ldx Y_tab_new+16,y		;add 16 because 16 line sprite height
	lda nr_sprite 			;sprite number
	inc sprite_zone,x
	lda colorwidth			;color + width
	sta (sprite_zone,x)
	inc sprite_zone,x
	lda tab_y_16_Holey,y 	;Holey DMA
	inc sprite_zone,x
	lda x_player			;x position
	sta (sprite_zone,x)
	inc sprite_zone,x
	rts
;put second zero on end for all Display Lists
add_endDl
	ldx #$00
	lda #$00
loopenddl
	inc sprite_zone,x	;skip to second byte of double zero for DL (terminate DL)
	sta (sprite_zone,x)
	inx
	inx
	cpx #13*2
	bne loopenddl
	rts
; :13 means Repat 13 times this line
; MWA is MADS macro - move word, # - is counter, starting from zero and increase every repaert
	:13	mwa #[FirstDL+[#*128]] sprite_zone+[#*2]
;you can use +5 after FirstDL if you need put extra 5 byte header for the background
;	:13	mwa #[FirstDL+5+[#*128]] sprite_zone+[#*2]
; this looks like this
;	lda #<$4000
;	sta sprite_zone
;	lda #>$4000
;	sta sprite_zone+1
;	lda #<[$4000+128*1]
;	sta sprite_zone+2
;	lda #[>$4000+128*1]
;	sta sprite_zone+3
;	lda #<[$4000+128*2]
;	sta sprite_zone+4
;	lda #[>$4000+128*2]
;	sta sprite_zone+5
;	etc....
; 13 times (LSB and MSB), but entry 13 is dummy - for anything outside line zone 0 to 11
; address willby FirstDL+[128*12] but you can set anywher you need (but the best will be on the beginning memory page
; because I'm using only INC (sprite_zone,x) - increasing only LSB - making faster
	rts
clear_dl_first
;zero all sprites at begining
	lda #$00
	:13 sta FirstDL+[[#*128]+1]	;plus 1 on end because second zero teminate DL
;		:13 sta FirstDL+5+[[#*128]+1]
;looks like this
;	sta $4000
;	sta $4000+128
;	sta $4000+128*2
;	etc....
	rts
Y_tab_new		;address on zero page for INDIRECT,X
	:16 .byte 0
;looks like
;  :16 - means repeat 16 times
; .byte 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	:16 .byte 2
	:16 .byte 4
	:16 .byte 6
	:16 .byte 8
	:16 .byte 10
	:16 .byte 12
	:16 .byte 14
	:16 .byte 16
	:16 .byte 18
	:16 .byte 20
	:16 .byte 22
	:16 .byte 24	;empty - this is dummy line, anything outside zones 0-11 will be written to (indirect+24),x
					;but never put on screen, it's easier to put sprite in dummy DL than checking every sprite leaving screen in Y axis
					;addres for Dummy DL you can put wherewer you want (page align)
	:16 .byte 24	;empty
	:16 .byte 24	;empty
	:16 .byte 24	;empty
	:16 .byte 24
sprbank equ $E0		;MSB of $E000 bank maria
holbank	equ $D0		;MSB of $D000 HoleyDMA bank
Tab_Y_16
;every line looks like this
; .byte sprbank+0,sprbank+1,sprbank+2,sprbank+3,sprbank+4,sprbank+5,sprbank+6,sprbank+7,.........., sprbank+15
; lines are 16 times repeated  - for speedcode reason (256 bytes table)
	:16 .byte sprbank+#
	:16 .byte sprbank+#
	:16 .byte sprbank+#
	:16 .byte sprbank+#
	:16 .byte sprbank+#
	:16 .byte sprbank+#
	:16 .byte sprbank+#
	:16 .byte sprbank+#
	:16 .byte sprbank+#
	:16 .byte sprbank+#
	:16 .byte sprbank+#
	:16 .byte sprbank+#
	:16 .byte sprbank+#
	:16 .byte sprbank+#
	:16 .byte sprbank+#
	:16 .byte sprbank+#
Tab_Y_16_Holey
	:16 .byte holbank+#
	:16 .byte holbank+#
	:16 .byte holbank+#
	:16 .byte holbank+#
	:16 .byte holbank+#
	:16 .byte holbank+#
	:16 .byte holbank+#
	:16 .byte holbank+#
	:16 .byte holbank+#
	:16 .byte holbank+#
	:16 .byte holbank+#
	:16 .byte holbank+#
	:16 .byte holbank+#
	:16 .byte holbank+#
	:16 .byte holbank+#
	:16 .byte holbank+#
Edited by Eagle
  • Thanks 2
Nice!
I used Dynamic DL creation in ReZolve (I promise to finish that at some point)...
But I will look this over.
Always open to new suggestions... to learning a more efficient way of doing things. ;)
Thank you!
Edited by PacManPlus
