Need help edditing this code for use with a 6x4 sprite
Cubwyn2600
Here is the program:
     rem ************************************************************************
     rem A project by Viggo Ö Waller
     set kernel_options no_blank_lines
     set tv pal
     set romsize 16k
     set optimization speed
     set optimization size
     set smartbranching on
     set optimization noinlinedata
     set optimization inlinerand
     playfield:
     XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
     X..............................X
     X...XXXXX.XXX.XXXXX.X....XXXX..X
     X.....X....X....X...X....X.....X
     X.....X....X....X...X....XXX...X
     X.....X...XXX...X...XXXX.XXXX..X
end
title
     COLUBK = $00
     COLUPF = $0E
     drawscreen
     if joy0fire || joy1fire then goto skiptitle
     goto title
skiptitle
     playfield:
     X...............................
end
     COLUBK = $00
     missile0height = 4  : missile0y = 255
     NUSIZ0 = $00
     score = 00000 :  scorecolor = $0E
     const _P_Edge_Top = 11
     const _P_Edge_Bottom = 88
     const _P_Edge_Left = 1
     const _P_Edge_Right = 153
     AUDV0 = 0 : AUDV1 = 0
     COLUP1 = $0E
     COLUP0 = $0E
     COLUPF = $0E
     player0:
     %0110
     %0110
     %1111
     %1010
     %1111
     %1001
end
     player0x = 77 : player0y = 53
__main
     if !joy0up then goto __Skip_Joy0_Up
     if player0y <= _P_Edge_Top then goto __Skip_Joy0_Up
     temp5 = (player0x-10)/4
     temp6 = (player0y-9)/8
     if temp5 < 34 then if pfread(temp5,temp6) then goto __Skip_Joy0_Up
     temp4 = (player0x-17)/4
     if temp4 < 34 then if pfread(temp4,temp6) then goto __Skip_Joy0_Up
     temp3 = temp5 - 1
     if temp3 < 34 then if pfread(temp3,temp6) then goto __Skip_Joy0_Up
     player0y = player0y - 1
__Skip_Joy0_Up
     if !joy0down then goto __Skip_Joy0_Down
     if player0y >= _P_Edge_Bottom then goto __Skip_Joy0_Down
     temp6 = (player0y)/8
     if temp5 < 34 then if pfread(temp5,temp6) then goto __Skip_Joy0_Down
     if temp4 < 34 then if pfread(temp4,temp6) then goto __Skip_Joy0_Down
     temp3 = temp5 - 1
     if temp3 < 34 then if pfread(temp3,temp6) then goto __Skip_Joy0_Down
     player0y = player0y + 1
__Skip_Joy0_Down
     if !joy0left then goto __Skip_Joy0_Left
     if player0x <= _P_Edge_Left then goto __Skip_Joy0_Left
     temp5 = (player0y-1)/8
     temp6 = (player0x-18)/4
     if temp6 < 34 then if pfread(temp6,temp5) then goto __Skip_Joy0_Left
     temp3 = (player0y-8)/8
     if temp6 < 34 then if pfread(temp6,temp3) then goto __Skip_Joy0_Left
     player0x = player0x - 1
__Skip_Joy0_Left
     if !joy0right then goto __Skip_Joy0_Right
     if player0x >= _P_Edge_Right then goto __Skip_Joy0_Right
     temp6 = (player0x-9)/4
     if temp6 < 34 then if pfread(temp6,temp5) then goto __Skip_Joy0_Right
     if temp6 < 34 then if pfread(temp6,temp3) then goto __Skip_Joy0_Right
     player0x = player0x + 1
__Skip_Joy0_Right
     if joy0left then a = a - 1
     if joy0right then a = a + 1
     if joy0left || joy0right then goto __skip_y_anim
     if joy0up then b = b + 1
     if joy0down then b = b - 1
     if  b  = 0 then player0:
     %1001
     %0110
     %1111
     %0101
     %1111
     %1001
end
     if b = 5 then player0:
     %0110
     %0110
     %1111
     %0101
     %1111
     %1001
end
     if b = 15 then player0:
     %0110
     %0110
     %1111
     %1010
     %1111
     %1001
end
     if b = 20 then player0:
     %1001
     %0110
     %1111
     %1010
     %1111
     %1001
end
__skip_y_anim
     if  a  = 0 then player0:
     %1001
     %0110
     %1111
     %0101
     %1111
     %1001
end
     if a = 5 then player0:
     %0110
     %0110
     %1111
     %0101
     %1111
     %1001
end
     if a = 15 then player0:
     %0110
     %0110
     %1111
     %1010
     %1111
     %1001
end
     if a = 20 then player0:
     %1001
     %0110
     %1111
     %1010
     %1111
     %1001
end
     if a = 0 then a = 10
     if a = 20 then a = 10
     if b = 0 then b = 10
     if b = 20 then b = 10
     drawscreen
__skipmove
     goto __main
Thanks for any help :)
- Viggo
Edited by Cubwyn2600
you didn't say what the problem is
the code looks like it's for 8x8 sprites
playfield pixels are 4x8 player pixels and
the playfield coordinates don't jibe with player coordinates
the player movement code does collision detection by converting player coordinates
to playfield pixels and checking to see if there's a playfield pixel in the way
it does the conversion by adding an offset to the player position and dividing by 4 (for x) or 8 (for y)
you probably want to adjust the offsets to compensate for the difference in the sprite dimensions
Edited by bogax
clarification
And what should those variables be changed to fit my sprite? Also, thanks for the help really need it 😕
Clarification
