Critique my first basic program on my 800XL
The minimal "smarter" technique which C= Basic employs is to simply compare the destination to current line, then just scan forward if > or start from beginning of program if <
Though the C= Basic only gets it partially right, it only checks if the high byte of the destination is greater but you can force proper search by creative usage of line numbering.
On 2/28/2024 at 9:36 PM, phaeron said:
Yes, it's a known bug/limitation in the OS:
GET/PUT wouldn't be any better, unless you buffer enough data to ensure that the first cassette record is written before DOS fetches another sector.
I see. Here is another copy Disk to CAS with a 1K buffer. Again this is reading at the byte level, so it shouldn't matter what kind of file it's copying. This program reuses the buffer over and over so size shouldn't matter. (That's what she said...😆)
10 OPEN #1,4,0,"D2:TEMP.LG"
20 FR=1:REM First Run Flag Set -- OPEN 'C:' only once
30 CLR: DIM BUF$(1024):REM CLeaR DIMmed strings so we don't end up with extra data after the EOF occurs
40 TRAP 95:FOR I=1 TO 1024
50 GET #1,A: BUF$(I,I)=CHR$(A)
60 NEXT I:IF FR THEN OPEN #2,8,0,"C:":FR=0:REM OPEN 'C:' right before output to compensate for OS bug
70 ? #2,BUF$;
80 GOTO 30
90 REM Trapped EOF brings us here
95 IF FR THEN OPEN #2,8,0,"C:":REM If file is less than 1K TRAP and subsequent write will occur before OPEN 'C:'. Must check for it again before write.
100 ? #2,BUF$;:CLOSE #1:CLOSE #2:REM Output remaining string contents and CLOSE all IOCBs
110 END
Edited by Houdini
Fixed file less than 1K bug.
  • Thanks 2
