So, I was thinking today since I got a new laser cutter/engraving device was if I could use it to make a decent single-sided PCB.  This was so much easier than the toner transfer method!  I wanted to share this experience for all the other DIYers that like to make their own PCB and may have a laser engraver at their disposal.
First to let everyone know I purchased the xTool S1 20 watt version diode laser.
After some testing I was able to get what looks to be a usable PCB and it passes all continuity test too.  Just need to assemble it for a final test.
First, I tried to just use a sharpie to color the board and then invert the mirrored image to engrave.  But that did not really work that well, so I decided to paint the copper board and use the laser to engrave off the paint that was not going to be traces.
Once the paint dried, I put it on bed of my laser engraver, squared it up and got it ready to engrave.  I engraved a couple of different mirrored inverted images of a couple of different boards.  The laser engraved the paint right off as I wanted it to.  See below for the results.
I cut the board in 1/2 and put it in the etching solution and left it for probably an hour.  Took all the copper off where the paint was engraved off.
Using some acetone, I removed the paint from the copper that remained on the board, and I have to say that I am pretty impressed by the results.
For anyone that wants to know my engraving settings that I used they are below:
xTool S1 20 watt diode laser
Selected material 3mm basswood plywood since I was just taking off paint.
Power = 60%
Speed = 120mm/s
Pass = 1
Bitmap mode = grayscale
lines per cm = 100
Engraving mode = Bidirectional
Edited by Shift838
  • Like 11
Yay! Laser PCBs!
I once hoped that the laser precision would allow for prototyping finer traces. But in my experiments, I only got as far as a working 1-sided Arduino with 0.1".
What etch process did you use? I found the "regenerating copper chloride" process quite efficient. Vibrate the solution every minute or so.
I see you etched away a large  area. I would try to minimize the copper being removed. That conserves your solution.
Another trick that I liked--if you are rasterizing a design, is to burn vector outlines of the traces.
It looks like you hit upon a good paint for this. My friends and I tried a bunch of spray paints before getting one that stuck well all through the etching.
Have fun with your laser! I know you are creative and persistent!
  • Like 5
