kevin6569 Posted April 24 Share Posted April 24 This is a weird one. I'm using an LTO flash cartridge with an original Intellivision and I can scroll through the menu, my controller functions properly. Once the game is selected, the controllers don't work. I've tried it with another original Intellivision, and everything works fine. Any thoughts on the problem? Quote Link to comment Share on other sites More sharing options...
+Lathe26 Posted April 25 Share Posted April 25 When you select a game, the LTO issues the reset signal to the Intellivision. Some Intellivisions don't response so the LTO + Intellivision look hung. I have an Intellivision that does the same thing. Just do a quick tap on the Reset button and the game should start. Quote Link to comment Share on other sites More sharing options...
nick3092 Posted April 25 Share Posted April 25 I believe there is a bipolar 1uf cap in the reset circuit. If it's a reset issue, replacing that may fix it. Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted April 30 Share Posted April 30 On 4/25/2024 at 8:44 AM, nick3092 said: I believe there is a bipolar 1uf cap in the reset circuit. If it's a reset issue, replacing that may fix it. Yeap, I've been replacing them out with 4.7 MLCC variants I get from Console5 in bulk. The increased capacitance doesn't effect the operation of the reset circuit in this case in a noticed way so if you have anything from about 1 - 4.7µf, should be good to go. Quote Link to comment Share on other sites More sharing options...
kevin6569 Posted May 27 Author Share Posted May 27 Thank you for possible solutions. I have another Intellivision I was using, but I like the picture on the one with the controller issue better. Turns out the mylar in the controller needed to be cleaned - I found this out after I recapped the whole system. Well, at least it should last me another 20 years. Quote Link to comment Share on other sites More sharing options...
