Jess Ragan Posted May 22 Share Posted May 22 Silly question, but I might as well ask. Programs written with CVBasic 4.0 are entirely compatible with 5.0, right? Quote Link to comment https://forums.atariage.com/topic/365682-colecovision-wonder-tastic-basic-compiler-cvbasic-v050-now-with-bank-switching-support/page/4/#findComment-5471105 Share on other sites More sharing options...
artrag Posted May 22 Share Posted May 22 Yes Quote Link to comment https://forums.atariage.com/topic/365682-colecovision-wonder-tastic-basic-compiler-cvbasic-v050-now-with-bank-switching-support/page/4/#findComment-5471127 Share on other sites More sharing options...
+nanochess Posted May 22 Author Share Posted May 22 11 hours ago, Jess Ragan said: Silly question, but I might as well ask. Programs written with CVBasic 4.0 are entirely compatible with 5.0, right? That's right, and you get the immediate advantage of extra optimization, fewer bugs in the compiler, and new statements that you can apply in your game. Quote Link to comment https://forums.atariage.com/topic/365682-colecovision-wonder-tastic-basic-compiler-cvbasic-v050-now-with-bank-switching-support/page/4/#findComment-5471427 Share on other sites More sharing options...
drfloyd Posted May 22 Share Posted May 22 Hello Why the result is 0 ????? t$="HELLO" print at 0,t$ Quote Link to comment https://forums.atariage.com/topic/365682-colecovision-wonder-tastic-basic-compiler-cvbasic-v050-now-with-bank-switching-support/page/4/#findComment-5471485 Share on other sites More sharing options...
+nanochess Posted May 22 Author Share Posted May 22 20 minutes ago, drfloyd said: Hello Why the result is 0 ????? t$="HELLO" print at 0,t$ Because it doesn't have string variables. The $ character is ignored in the second line, and in the first line it should be throwing an error. Quote Link to comment https://forums.atariage.com/topic/365682-colecovision-wonder-tastic-basic-compiler-cvbasic-v050-now-with-bank-switching-support/page/4/#findComment-5471498 Share on other sites More sharing options...
drfloyd Posted May 22 Share Posted May 22 ok thanks, It will be perhaps a problem for my role game 😕 Will think about that. Quote Link to comment https://forums.atariage.com/topic/365682-colecovision-wonder-tastic-basic-compiler-cvbasic-v050-now-with-bank-switching-support/page/4/#findComment-5471508 Share on other sites More sharing options...
artrag Posted May 22 Share Posted May 22 Strings can be stored as DATA BYTE and plotted using SCREEN Quote Link to comment https://forums.atariage.com/topic/365682-colecovision-wonder-tastic-basic-compiler-cvbasic-v050-now-with-bank-switching-support/page/4/#findComment-5471627 Share on other sites More sharing options...
ZippyOasys Posted May 24 Share Posted May 24 @nanochess Is there a limit for how big a .VGM file should be? Quote Link to comment https://forums.atariage.com/topic/365682-colecovision-wonder-tastic-basic-compiler-cvbasic-v050-now-with-bank-switching-support/page/4/#findComment-5473015 Share on other sites More sharing options...
+nanochess Posted May 24 Author Share Posted May 24 35 minutes ago, ZippyOasys said: @nanochess Is there a limit for how big a .VGM file should be? Yes, you cannot exceed 30 KB in a simple ROM, and 15 KB in a bank-switched ROM. Unless you enhance the VGM player to advance the bank number. Quote Link to comment https://forums.atariage.com/topic/365682-colecovision-wonder-tastic-basic-compiler-cvbasic-v050-now-with-bank-switching-support/page/4/#findComment-5473041 Share on other sites More sharing options...
Jess Ragan Posted May 24 Share Posted May 24 Just out of curiosity, how long would a VGM melody have to be to reach 15K? (I used one of the sample programs to make the ColecoVision play the theme song from Alex Kidd in Miracle World. That was a little freaky!) Quote Link to comment https://forums.atariage.com/topic/365682-colecovision-wonder-tastic-basic-compiler-cvbasic-v050-now-with-bank-switching-support/page/4/#findComment-5473058 Share on other sites More sharing options...
+nanochess Posted May 24 Author Share Posted May 24 2 hours ago, Jess Ragan said: Just out of curiosity, how long would a VGM melody have to be to reach 15K? (I used one of the sample programs to make the ColecoVision play the theme song from Alex Kidd in Miracle World. That was a little freaky!) In fact, a VGM file can reach that limit pretty fast because it has a lot of overhead. For example, turning on a channel in 440 hz is: $8e $0f $93 (or equivalent SOUND 0,$FE,12) these 3 bytes are each prefixed each one with $50 in the VGM file format. So putting a tone in one channel requires 6 bytes in a VGM file, plus one extra byte to signal the end of the sound frame. Now supposing the worst case where it turns on the three channels in one frame (3*6 + 1 = 19 bytes), and then turns off the three channels in the next frame (3*2 + 1 = 7 bytes) then it is 780 bytes per second, or 19.69 seconds of music in 15K. A "normal" song could easily run for 60 or 90 seconds in 15K. Quote Link to comment https://forums.atariage.com/topic/365682-colecovision-wonder-tastic-basic-compiler-cvbasic-v050-now-with-bank-switching-support/page/4/#findComment-5473148 Share on other sites More sharing options...
Pixelboy Posted May 24 Share Posted May 24 Noob question incoming: Does the VGM format have anything to do with the sound-related routines in the ColecoVision BIOS? I'm asking because I recall Newcoleco's presentations at ADAMCon about using the BIOS for generating music, and the actual data structure was rather compact. I may be misremembering though... Quote Link to comment https://forums.atariage.com/topic/365682-colecovision-wonder-tastic-basic-compiler-cvbasic-v050-now-with-bank-switching-support/page/4/#findComment-5473191 Share on other sites More sharing options...
artrag Posted May 24 Share Posted May 24 nothing to do Quote Link to comment https://forums.atariage.com/topic/365682-colecovision-wonder-tastic-basic-compiler-cvbasic-v050-now-with-bank-switching-support/page/4/#findComment-5473196 Share on other sites More sharing options...
+nanochess Posted May 24 Author Share Posted May 24 1 hour ago, Pixelboy said: Noob question incoming: Does the VGM format have anything to do with the sound-related routines in the ColecoVision BIOS? I'm asking because I recall Newcoleco's presentations at ADAMCon about using the BIOS for generating music, and the actual data structure was rather compact. I may be misremembering though... The Coleco BIOS isn't used for CVBasic, except for the SGM missing message. CVBasic includes a music player that is pretty efficient in terms of space usage for music and also uses the same music format as IntyBASIC. 1 Quote Link to comment https://forums.atariage.com/topic/365682-colecovision-wonder-tastic-basic-compiler-cvbasic-v050-now-with-bank-switching-support/page/4/#findComment-5473229 Share on other sites More sharing options...
ZippyOasys Posted May 24 Share Posted May 24 Quote A "normal" song could easily run for 60 or 90 seconds in 15K @nanochess How long can a .VGM song run in 30 kb? Quote Link to comment https://forums.atariage.com/topic/365682-colecovision-wonder-tastic-basic-compiler-cvbasic-v050-now-with-bank-switching-support/page/4/#findComment-5473260 Share on other sites More sharing options...
+nanochess Posted May 24 Author Share Posted May 24 1 hour ago, ZippyOasys said: @nanochess How long can a .VGM song run in 30 kb? An estimated of 120 to 180 seconds. Quote Link to comment https://forums.atariage.com/topic/365682-colecovision-wonder-tastic-basic-compiler-cvbasic-v050-now-with-bank-switching-support/page/4/#findComment-5473315 Share on other sites More sharing options...
ZippyOasys Posted May 24 Share Posted May 24 30 minutes ago, nanochess said: An estimated of 120 to 180 seconds. Game Logic included? Quote Link to comment https://forums.atariage.com/topic/365682-colecovision-wonder-tastic-basic-compiler-cvbasic-v050-now-with-bank-switching-support/page/4/#findComment-5473334 Share on other sites More sharing options...
+nanochess Posted May 24 Author Share Posted May 24 4 minutes ago, ZippyOasys said: Game Logic included? Of course not. It is the maximum you can use with almost no code. Quote Link to comment https://forums.atariage.com/topic/365682-colecovision-wonder-tastic-basic-compiler-cvbasic-v050-now-with-bank-switching-support/page/4/#findComment-5473336 Share on other sites More sharing options...
ZippyOasys Posted May 24 Share Posted May 24 (edited) 4 minutes ago, nanochess said: Of course not. It is the maximum you can use with almost no code. So, how long would a song be with game code for 30kb? Edited May 24 by ZippyOasys Quote Link to comment https://forums.atariage.com/topic/365682-colecovision-wonder-tastic-basic-compiler-cvbasic-v050-now-with-bank-switching-support/page/4/#findComment-5473338 Share on other sites More sharing options...
+nanochess Posted May 25 Author Share Posted May 25 14 minutes ago, ZippyOasys said: So, how long would a song be with game code for 30kb? Haha, are you kidding? It is just estimations. 32k - 30k = 2k 32k / 120 seconds = 0.26k per second (estimated) 2k / 0.26 = 7 seconds. Please note that these are estimated values. You would be better doing music with the integrated music player. As I said before VGM is overloaded, half of the file is composed by $50 bytes. Quote Link to comment https://forums.atariage.com/topic/365682-colecovision-wonder-tastic-basic-compiler-cvbasic-v050-now-with-bank-switching-support/page/4/#findComment-5473344 Share on other sites More sharing options...
Jess Ragan Posted May 25 Share Posted May 25 So... I'm working on an MSX version of Whack 'Em Smack 'Em Byrons. After moving the SOUND channels from 2 and 3 to 7 and 8, everything works fine in OpenMSX, except! The fiery explosion that happens when you hit a bomb is no longer there. Are the frequencies I'm using (67-237) too low for the MSX? Will I need to move over to the MIX channel (channel 9) for rumbly explosions? Furthermore, there's talk in the manual that if I don't use specific values (80-191) with MIX, the MSX will hold and catch fire (!!!). I guess it wouldn't be a big deal in an emulator... the worst case scenario is that the emulator would crash and need to be restarted. However, in the unlikely event that someone puts this on a real MSX, that's going to be a big problem. (Good lord, it's hard to believe hold and catch fire is even a thing in consumer technology.) Quote Link to comment https://forums.atariage.com/topic/365682-colecovision-wonder-tastic-basic-compiler-cvbasic-v050-now-with-bank-switching-support/page/4/#findComment-5473440 Share on other sites More sharing options...
drfloyd Posted May 25 Share Posted May 25 Hi, I understand the lake of STRING$ in CVBASIC, not usefull for Arcade games (99% of the games) Not easy for me as I try to do a big role game on Coleco... but it is an exception I will do with special routines.... (thanks Nano for your routine) But for MSX games, this lack is not a problem ???? Seems strange a basic without string for big codes. Quote Link to comment https://forums.atariage.com/topic/365682-colecovision-wonder-tastic-basic-compiler-cvbasic-v050-now-with-bank-switching-support/page/4/#findComment-5473480 Share on other sites More sharing options...
artrag Posted May 25 Share Posted May 25 9 hours ago, Jess Ragan said: So... I'm working on an MSX version of Whack 'Em Smack 'Em Byrons. After moving the SOUND channels from 2 and 3 to 7 and 8, everything works fine in OpenMSX, except! The fiery explosion that happens when you hit a bomb is no longer there. Are the frequencies I'm using (67-237) too low for the MSX? Will I need to move over to the MIX channel (channel 9) for rumbly explosions? Furthermore, there's talk in the manual that if I don't use specific values (80-191) with MIX, the MSX will hold and catch fire (!!!). I guess it wouldn't be a big deal in an emulator... the worst case scenario is that the emulator would crash and need to be restarted. However, in the unlikely event that someone puts this on a real MSX, that's going to be a big problem. (Good lord, it's hard to believe hold and catch fire is even a thing in consumer technology.) Be aware that the ay8910 works differently by the sn789 of the colecovision. The tones have a wider range of periods (12bits vs 10 bits) but the noise is added (by xor, so it in multiplied rather than added) to one, two or three tone channels. The mixer is in charge to select which channels will have noise, tone or both. If you do not set the mixer you do not get noise. Colecovision has a separate noise channel whose volume is set by one of the other tone channels. Quote Link to comment https://forums.atariage.com/topic/365682-colecovision-wonder-tastic-basic-compiler-cvbasic-v050-now-with-bank-switching-support/page/4/#findComment-5473597 Share on other sites More sharing options...
artrag Posted May 25 Share Posted May 25 7 hours ago, drfloyd said: Hi, I understand the lake of STRING$ in CVBASIC, not usefull for Arcade games (99% of the games) Not easy for me as I try to do a big role game on Coleco... but it is an exception I will do with special routines.... (thanks Nano for your routine) But for MSX games, this lack is not a problem ???? Seems strange a basic without string for big codes. When you have 1k of ram, having strings in ram can be very tricky. About the msx, where you have ram, you can manage with arrays the same functions you would have with strings. You only need to implement the functions you need. One thing you can use to make your code more readable, is to access to DATA BYTE using the array sintax. TestArray: DATA BYTE 65,66,67,0,68,69,70,0 varptr TestArray[0] is aiming to ABC varptr TestArray[5] is aiming to DEF Quote Link to comment https://forums.atariage.com/topic/365682-colecovision-wonder-tastic-basic-compiler-cvbasic-v050-now-with-bank-switching-support/page/4/#findComment-5473601 Share on other sites More sharing options...
drfloyd Posted May 25 Share Posted May 25 I understand for the RAM, but CVBasic is also available for MSX (64ko ?) For Coleco, It is not possible to have a string option only for ROM ? Quote Link to comment https://forums.atariage.com/topic/365682-colecovision-wonder-tastic-basic-compiler-cvbasic-v050-now-with-bank-switching-support/page/4/#findComment-5473738 Share on other sites More sharing options...
