TGB1718 Posted May 17 Share Posted May 17 When I use the debugger in Altirra, whenever I access D1: or D2: I get a stream of messages (100's) in the Console (see below) This obviously gets in the way of normal monitoring, is there a way to turn this off ? It never used to do this, I think I may have accidentally turned it on, but for the life of me I can't see where to turn it off DISKEMU: Stepper phases now: 2C FDC: Physical track is now 4.5 DISKEMU: Stepper phases now: 34 FDC: Physical track is now 5.0 DISKEMU: Stepper phases now: 38 FDC: Physical track is now 5.5 DISKEMU: Stepper phases now: 1C Quote Link to comment Share on other sites More sharing options...
Rybags Posted May 17 Share Posted May 17 I can't see any debug command that would generate that - do you have a specific drive defined in devices? This is below SIO or serial tracing, it's as if it's showing the actual drive firmware's stepping commands. 1050 and I think 810 do 2 step phase changes to move 1 track. Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted May 17 Share Posted May 17 This looks like logs from Full Disk Emulation. Quote Link to comment Share on other sites More sharing options...
Rybags Posted May 17 Share Posted May 17 Agreed - I can't seem to find a 1050 firmware here so can't recreate the situation properly. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted May 17 Author Share Posted May 17 2 hours ago, Rybags said: do you have a specific drive defined in devices? I have the drives mapped as 1050 with USD, same as my real setup, I'll try digging a bit deeper to see if I can find how to turn it off Quote Link to comment Share on other sites More sharing options...
Rybags Posted May 17 Share Posted May 17 (edited) Maybe try in the debugger: .traceser off .tracesio off Actually, I thought these options weren't persistent. Generally debugger stuff like breakpoints only exist for the duration of the Altirra run. Edited May 17 by Rybags 2 Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted May 17 Author Share Posted May 17 11 minutes ago, Rybags said: Maybe try in the debugger: .traceser off .tracesio off Many, Many thanks, that fixed it, like you, I didn't think commands existed after shutting it down 👍👍👍 Quote Link to comment Share on other sites More sharing options...
phaeron Posted May 17 Share Posted May 17 "lfd fdc" and "lfd diskemu" to turn off these logging channels. 3 Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted June 4 Author Share Posted June 4 How do you get Altirra to keep these settings ? Every time I use the debugger I find I'm still getting tons of these messages, I have to manually turn these messages off then next day it's back, I've tried Save State and Quick Save State, but it's always the same when I restart. I'm running in Registry mode and have tried switching to Portable mode, but it still does this, is there a way to make Altirra save the current debugger settings (in fact all settings as a lot of the time it removes attached drives between sessions too) FDC: Physical track is now 18.0 DISKEMU: Stepper phases now: 2C FDC: Physical track is now 18.5 DISKEMU: Stepper phases now: 34 FDC: Physical track is now 19.0 DISKEMU: Stepper phases now: 38 FDC: Physical track is now 19.5 DISKEMU: Stepper phases now: 34 FDC: Physical track is now 19.0 DISKEMU: Stepper phases now: 38 FDC: Physical track is now 19.5 DISKEMU: Stepper phases now: 1C FDC: Physical track is now 20.0 DISKEMU: Stepper phases now: 2C FDC: Physical track is now 20.5 DISKEMU: Stepper phases now: 1C FDC: Physical track is now 20.0 DISKEMU: Stepper phases now: 3C Quote Link to comment Share on other sites More sharing options...
phaeron Posted June 5 Share Posted June 5 Altirra saves most non-debugger settings by default, but be aware that if you open more than one copy of the program at a time, they may stomp on each other when saving settings. This is worse in portable mode than in registry mode. You can place commands in a file called startup.atdbg next to the program executable to auto-run those commands when the debugger initializes. 1 Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted June 5 Author Share Posted June 5 7 hours ago, phaeron said: Altirra saves most non-debugger settings by default, but be aware that if you open more than one copy of the program at a time, they may stomp on each other when saving settings. No, I never run more than one copy at a time, learnt the problems associated with that many years ago 7 hours ago, phaeron said: You can place commands in a file called startup.atdbg next to the program executable to auto-run those commands when the debugger initializes. Thanks, I'll try that today, I just ran Altirra and it's still outputting those drive commands, so before I switch them off manually, I'll create this file and run it again 👍 Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted June 5 Author Share Posted June 5 8 hours ago, phaeron said: You can place commands in a file called startup.atdbg next to the program executable to auto-run those commands when the debugger initializes. Thanks again that worked a treat, been annoying me for ages. One thing though, I couldn't find any reference to using that file in any documentation. I still think the main problem is that Altirra is not saving those settings on exit regardless of registry or portable mode, I remember turning those settings on a long time ago to debug a disk based program and obviously it saved that, but won't save the turn off, strange Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted June 5 Share Posted June 5 6 hours ago, TGB1718 said: turning those settings on a long time ago to debug a disk based program and obviously it saved that, but won't save the turn off, strange Did you check whether you have full disk emulation activated for a drive? My Altirra never shows these logs with standard disk emulation but always shows them with full disk emulation. (Both certainly unless I change it explicitly.) Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted June 5 Author Share Posted June 5 42 minutes ago, DjayBee said: Did you check whether you have full disk emulation activated for a drive? Yes I have it emulating D1: and D2: as USD drives, same as my real hardware, I'll have a play tomorrow and see if that also fixes it. Quote Link to comment Share on other sites More sharing options...
