TrickyMoon Posted November 24 Share Posted November 24 (edited) 43 minutes ago, aotta said: @TrickyMoon I think it's something wrong with the .cfg files... Hi @aotta Looking at Backgammon, the cfg looks ok. When I try to select this game, same thing happens. Any other thoughts on what could cause? Thanks!! [mapping] $0000 - $1FFF = $5000 ; 8K to $5000 - $6FFF $2000 - $2FFF = $D000 ; 4K to $D000 - $DFFF $3000 - $3FFF = $F000 ; 4K to $F000 - $FFFF Edited November 24 by TrickyMoon Quote Link to comment https://forums.atariage.com/topic/366700-pirto-ii-multicart-just-published/page/5/#findComment-5571455 Share on other sites More sharing options...
aotta Posted November 24 Author Share Posted November 24 Deoes the pico's led flash? Quote Link to comment https://forums.atariage.com/topic/366700-pirto-ii-multicart-just-published/page/5/#findComment-5571458 Share on other sites More sharing options...
TrickyMoon Posted November 24 Share Posted November 24 6 minutes ago, aotta said: Deoes the pico's led flash? It’s flashing green Quote Link to comment https://forums.atariage.com/topic/366700-pirto-ii-multicart-just-published/page/5/#findComment-5571462 Share on other sites More sharing options...
aotta Posted November 24 Author Share Posted November 24 the number of flashes between the longer pause is the code error, please report it Quote Link to comment https://forums.atariage.com/topic/366700-pirto-ii-multicart-just-published/page/5/#findComment-5571465 Share on other sites More sharing options...
TrickyMoon Posted November 24 Share Posted November 24 Ah, hang on. Demon Attach and DigDug just worked... let me check those .cfg to see how they could be different. Quote Link to comment https://forums.atariage.com/topic/366700-pirto-ii-multicart-just-published/page/5/#findComment-5571468 Share on other sites More sharing options...
TrickyMoon Posted November 24 Share Posted November 24 2 minutes ago, aotta said: the number of flashes between the longer pause is the code error, please report it ok, will do. Thx Quote Link to comment https://forums.atariage.com/topic/366700-pirto-ii-multicart-just-published/page/5/#findComment-5571470 Share on other sites More sharing options...
TrickyMoon Posted November 24 Share Posted November 24 (edited) 12 minutes ago, aotta said: the number of flashes between the longer pause is the code error, please report it It's just the same single flash and a long pause. 10 minutes ago, TrickyMoon said: Ah, hang on. Demon Attach and DigDug just worked... Most ROMs aren't working so, like you said I assume it's the .cfg, is there any resource for what the mappings should be? #ABPA Backgammon - Not working [mapping] $0000 - $1FFF = $5000 ; 8K to $5000 - $6FFF $2000 - $2FFF = $D000 ; 4K to $D000 - $DFFF $3000 - $3FFF = $F000 ; 4K to $F000 - $FFFF Dreadnaught Factor - Not working [mapping] $0000 - $1FFF = $5000 ; 8K to $5000 - $6FFF $2000 - $2FFF = $D000 ; 4K to $D000 - $DFFF $3000 - $3FFF = $F000 ; 4K to $F000 - $FFFF Demon Attack - Working [mapping] $0000 - $1FFF = $4800 ; 8K to $4800 - $67FF DigDug - Working [mapping] $0000 - $2FFF = $5000 ; 12K to $5000 - $7FFF $3000 - $5FFF = $9000 ; 12K to $9000 - $BFFF Edited November 24 by TrickyMoon Quote Link to comment https://forums.atariage.com/topic/366700-pirto-ii-multicart-just-published/page/5/#findComment-5571482 Share on other sites More sharing options...
aotta Posted November 24 Author Share Posted November 24 i'll not check the single cfg files, but you'll find all needed info here: Just be sure to have "0.cfg" file in root directory, and that all games with config different from the 0.cfg one have their config with the EXACT SAME NAME that .bin name but with the .cfg suffix. Quote Link to comment https://forums.atariage.com/topic/366700-pirto-ii-multicart-just-published/page/5/#findComment-5571489 Share on other sites More sharing options...
TrickyMoon Posted November 24 Share Posted November 24 @aotta Thanks for the help. Was just reading that thread. I'll confirm everything with the 0.cfg file and play around with the individual ones. Thanks again. Quote Link to comment https://forums.atariage.com/topic/366700-pirto-ii-multicart-just-published/page/5/#findComment-5571495 Share on other sites More sharing options...
Onlyfordj Posted November 30 Share Posted November 30 On 9/11/2024 at 4:34 PM, Tissemon said: Oh, and a little FYI for everybody. All .ROM-files can be converted to bin+cfg. Download JZIntv for Windows here: http://spatula-city.org/~im14u2c/intv/ Unpack it to a folder, and in that folder you will find a subfolder named BIN. In there you have rom2bin.exe. Drag .rom-files to that .exe-file (or drag the .exe file to the .rom-file? Can't remember) - anyway it will create a bin+cfg for your .rom-game. You can also do it from cmd - just type rom2bin gamename.rom Easy-peasy! Hello... I'm doing something wrong. I'm using Windows 11 and following your instructions... I don't think it generates any bin file nor cfg file. Does it work on Windows 11? Where are the files supposedly generated? Quote Link to comment https://forums.atariage.com/topic/366700-pirto-ii-multicart-just-published/page/5/#findComment-5575551 Share on other sites More sharing options...
mr_me Posted November 30 Share Posted November 30 6 minutes ago, Onlyfordj said: Hello... I'm doing something wrong. I'm using Windows 11 and following your instructions... I don't think it generates any bin file nor cfg file. Does it work on Windows 11? Where are the files supposedly generated? If you put rom2bin.exe and yourgame.rom in the same folder, run "rom2bin yourgame.rom" at a command line without the quotes, it should give you error messages if it doesn't work. Quote Link to comment https://forums.atariage.com/topic/366700-pirto-ii-multicart-just-published/page/5/#findComment-5575555 Share on other sites More sharing options...
Onlyfordj Posted November 30 Share Posted November 30 (edited) Ok thank you very much. Ok, I understand. Perfect, now I do. Edited November 30 by Onlyfordj Quote Link to comment https://forums.atariage.com/topic/366700-pirto-ii-multicart-just-published/page/5/#findComment-5575556 Share on other sites More sharing options...
utri007 Posted December 3 Share Posted December 3 To avoid hasle, any links to purple Pico for a color blind person? Quote Link to comment https://forums.atariage.com/topic/366700-pirto-ii-multicart-just-published/page/5/#findComment-5577587 Share on other sites More sharing options...
Jboner1058 Posted December 3 Share Posted December 3 I’ve found that the Pirto doesn’t get along with the Super System 3. I’ve had 3 different super system users have compatibility issues with games not loading or garbled data. I’ve got a super system 3 coming from eBay soon and I’ll do some research here to finally confirm. 2 Quote Link to comment https://forums.atariage.com/topic/366700-pirto-ii-multicart-just-published/page/5/#findComment-5578015 Share on other sites More sharing options...
aotta Posted December 3 Author Share Posted December 3 24 minutes ago, Jboner1058 said: I’ve found that the Pirto doesn’t get along with the Super System 3. I’ve had 3 different super system users have compatibility issues with games not loading or garbled data. I’ve got a super system 3 coming from eBay soon and I’ll do some research here to finally confirm. Yes, other users reported issues with original games on Super Pro System with INTV II Exec chip (but homebrew ones and Gorf and Yars reported as working). I tested Pirto II with Inty classic, II, Secam, Pal, Super Video Arcade, but I don't have a Super Pro to perform further tests and fix it Quote Link to comment https://forums.atariage.com/topic/366700-pirto-ii-multicart-just-published/page/5/#findComment-5578037 Share on other sites More sharing options...
Crash7 Posted December 4 Share Posted December 4 1 hour ago, aotta said: Yes, other users reported issues with original games on Super Pro System with INTV II Exec chip (but homebrew ones and Gorf and Yars reported as working). I tested Pirto II with Inty classic, II, Secam, Pal, Super Video Arcade, but I don't have a Super Pro to perform further tests and fix it INTV Corp games work on my Super Pro with the INTV II EXEC chip as long as it has a CFG file. Mattel Classics do not. Rev/IntelligentVision homebrews like Striker Bowling and Space Invaders work. Yars Revenge works. Oscar's latest Pumpkin Bakery works. GORF does not. But all of these games, with the same PIRTO or PiRTO II cart, work in my Sears unit no problem. Quote Link to comment https://forums.atariage.com/topic/366700-pirto-ii-multicart-just-published/page/5/#findComment-5578094 Share on other sites More sharing options...
kschewe Posted December 5 Share Posted December 5 Mine works now the the purple clone. I could only find them on ebay. Is there a list of games that fully work with the cart? The original ones? If there is a premade rom pack for this let me know. If someone has one to share thanks. Or I can help make a full pack. Quote Link to comment https://forums.atariage.com/topic/366700-pirto-ii-multicart-just-published/page/5/#findComment-5578849 Share on other sites More sharing options...
Crash7 Posted December 5 Share Posted December 5 Etsy probably has a ROM pack of The originals. Quote Link to comment https://forums.atariage.com/topic/366700-pirto-ii-multicart-just-published/page/5/#findComment-5578862 Share on other sites More sharing options...
tep392 Posted December 5 Share Posted December 5 Please no posting links to ROM sites. 1 1 Quote Link to comment https://forums.atariage.com/topic/366700-pirto-ii-multicart-just-published/page/5/#findComment-5579260 Share on other sites More sharing options...
kschewe Posted December 7 Share Posted December 7 I was able to figure it out. I just assumed the cfg was unique to this cart. My roms are in .int but renaming them to bin and finding the corresponding cfg works. Is there a limit on rom size? I have not tried anything larger then 32k. Quote Link to comment https://forums.atariage.com/topic/366700-pirto-ii-multicart-just-published/page/5/#findComment-5579993 Share on other sites More sharing options...
