lbaeza Posted May 25 Share Posted May 25 (edited) Hi team The following is based on this Page Flipping tutorial found here: https://www.atarimagazines.com/v2n10/Pageflipping.html I made my own example of Page Flipping. It shows numbers 1 through 4 rotating on a square pattern. Check out the attached listing and disk image if you want to see it running. Problem is, on line 143 I am supposed to reserve memory, like this: 143 RT=PEEK(106)-32:POKE 106,RT How much memory should I reserve? According to this webpage: https://gury.atari8.info/refs/graphics_modes.php 1 screen of GRAPHICS 2 takes 240 bytes of memory. Since my animation is comprised of 8 frames, I need 240*8=1920 bytes, or 7 pages. This is the value I should subtract to PEEK(106) on line 143. However, if I do this, screen is filled with garbage. I had to keep incrementing this value up to 32, which makes possible to see the animation with no problems, until frame 8, where you can still see some garbage on screen. Why didn't subtracting 7 to PEEK(106) do the trick? Another question: Am I forced to reserve memory for a full GRAPHICS 2 screen, even though I am only changing the first 3 lines between animation frames? Please let me know. Kind regards, Luis. PS: Here's the listing: 100 REM PAGE FLIPPING DEMO 101 REM *** 104 REM INITIALIZE ANIMATION FRAMES 105 REM I$ CONTAINS ODD FRAMES, P$ EVEN FRAMES 110 DIM I$(36):I$=" ":I$(36)=" ":I$(2)=I$ 120 DIM P$(36):P$=" ":P$(36)=" ":P$(2)=P$ 130 I$="1 2 4 34 1 3 23 4 2 12 3 1 4" 140 P$=" 1 4 2 3 4 3 1 2 3 2 4 1 2 1 3 4 " 141 REM RESERVE FREE MEMORY FOR FRAMES 143 RT=PEEK(106)-32:POKE 106,RT 145 GRAPHICS 2+16 149 REM DX.W 1ST EVEN FRAME 150 POKE 88,0:POKE 89,RT:I=1:GOSUB 1000 159 REM DRAW 1ST ODD FRAME 160 POKE 88,0:POKE 89,RT+4:GOSUB 2000 169 REM DRAW 2ND EVEN FRAME 170 POKE 88,0:POKE 89,RT+8:I=4:GOSUB 1000 179 REM DRAW 2ND ODD FRAME 180 POKE 88,0:POKE 89,RT+12:GOSUB 2000 189 REM DRAW 3RD EVEN FRAME 190 POKE 88,0:POKE 89,RT+16:I=7:GOSUB 1000 199 REM DRAW 3RD ODD FRAME 200 POKE 88,0:POKE 89,RT+20:GOSUB 2000 209 REM DRAW 4TH EVEN FRAME 210 POKE 88,0:POKE 89,RT+24:I=10:GOSUB 1000 219 REM DRAW 4TH ODD FRAME 220 POKE 88,0:POKE 89,RT+28:GOSUB 2000 249 REM DLIST= DISPLAY LIST ADDRESS 250 DLIST=PEEK(560)+256*PEEK(561) 258 REM ASSIGN ADDRESS OF 1ST LINE 259 REM OF DISPLAY DATA IN DLIST TO SCREEN MEMORY 260 POKE 88,PEEK(DLIST+4):POKE 89,PEEK(DLIST+5) 278 REM ASSIGN 0 TO MSB OF ADDRESS OF 1ST LINE 279 REM OF DISPLAY DATA IN DLIST 280 POKE DLIST+4,0 288 REM ASSIGN THE BEGINNING OF RESERVED MEMORY + INCREMENT TO LSB 289 REM OF ADDRESS OF 1ST LINE OF DISPLAY DATA IN DLIST 290 POKE DLIST+5,RT:GOSUB 3000 300 POKE DLIST+5,RT+4:GOSUB 3000 310 POKE DLIST+5,RT+8:GOSUB 3000 320 POKE DLIST+5,RT+12:GOSUB 3000 330 POKE DLIST+5,RT+16:GOSUB 3000 340 POKE DLIST+5,RT+20:GOSUB 3000 350 POKE DLIST+5,RT+24:GOSUB 3000 360 POKE DLIST+5,RT+28:GOSUB 3000 370 GOTO 290 999 REM PRINT ANIMATION EVEN FRAME 1000 POSITION 0,0 1010 ? #6;I$(I*3-2,I*3) 1020 ? #6;I$((I+1)*3-2,(I+1)*3) 1030 ? #6;I$((I+2)*3-2,(I+2)*3) 1050 RETURN 1999 REM PRINT ANIMATION ODD FRAME 2000 POSITION 0,0 2010 ? #6;P$(I*3-2,I*3) 2020 ? #6;P$((I+1)*3-2,(I+1)*3) 2030 ? #6;P$((I+2)*3-2,(I+2)*3) 2050 RETURN 2999 REM PAUSE LOOP 3000 FOR P=1 TO 200:NEXT P:RETURN PAGEFLIP.atr Edited May 25 by lbaeza Grammar Quote Link to comment Share on other sites More sharing options...
Rybags Posted May 26 Share Posted May 26 The problem is likely when crossing a 4K boundary with the display data, and also the display list can't cross a 1K boundary. Gr. 2 uses 240 bytes for display and another 20 for display list so will use more than a page in total meaning these problems are possible. For a Graphics 2 array you'd need to space each occurrence 2 pages apart on a boundary divisible by 2. Your RAMTOP values then might be 160, 158, 156, 154 etc. Quote Link to comment Share on other sites More sharing options...
phaeron Posted May 26 Share Posted May 26 There are some cases where certain values of 106 (RAMTOP) cause issues due to hardware alignment requirements, but this doesn't seem to be one of them. It looks like the only issue here is needing to clear the additional pages. The OS will only clear enough memory for the graphics mode, so when you change 88 (SAVMSC) to point to the rest of the reserved memory, that memory still has whatever junk was there previously. Issuing a clear to start when drawing the other pages should fix that. Rows can be shared when page flipping, but you'll have to rewrite the display list pointed to by 560 (SDLSTL/SDLSTH). It requires inserting an additional LMS (load memory scan) instruction into the display list to reset the memory scan counter where you need the "split". The two bytes being changed at DLIST+4 and +5 are the address in the LMS instruction that the OS puts at the start of the display list. 1 Quote Link to comment Share on other sites More sharing options...
lbaeza Posted May 26 Author Share Posted May 26 (edited) Thanks for your comments! After reading them, I added the following line: 146 FOR I=38912 TO 40959:POKE I,0:NEXT I Frame 1 is stored at page 152 (152*256=38912) and Frame 8 is stored at page 159 (159*256=40704), ending at 40959. And this seems to have solved the issue. In addition to that, given that one screen of GRAPHICS 2 requires 240 bytes, 1 have "rounded" this to 256 bytes, i.e. 1 page. So the increment added to RT on lines from 150 to 220 is 1, and the same is done from lines 290 to 360. Here's the updated listing that works OK: 100 REM PAGE FLIPPING DEMO 101 REM *** 104 REM INITIALIZE ANIMATION FRAMES 105 REM I$ CONTAINS ODD FRAMES, P$ EVEN FRAMES 110 DIM I$(36):I$=" ":I$(36)=" ":I$(2)=I$ 120 DIM P$(36):P$=" ":P$(36)=" ":P$(2)=P$ 130 I$="1 2 4 34 1 3 23 4 2 12 3 1 4" 140 P$=" 1 4 2 3 4 3 1 2 3 2 4 1 2 1 3 4 " 141 REM RESERVE FREE MEMORY FOR FRAMES 143 RT=PEEK(106)-8:POKE 106,RT 145 GRAPHICS 2+16 146 FOR I=38912 TO 40959:POKE I,0:NEXT I 149 REM DRAW 1ST EVEN FRAME 150 POKE 88,0:POKE 89,RT:I=1:GOSUB 1000 159 REM DRAW 1ST ODD FRAME 160 POKE 88,0:POKE 89,RT+1:GOSUB 2000 169 REM DRAW 2ND EVEN FRAME 170 POKE 88,0:POKE 89,RT+2:I=4:GOSUB 1000 179 REM DRAW 2ND ODD FRAME 180 POKE 88,0:POKE 89,RT+3:GOSUB 2000 189 REM DRAW 3RD EVEN FRAME 190 POKE 88,0:POKE 89,RT+4:I=7:GOSUB 1000 199 REM DRAW 3RD ODD FRAME 200 POKE 88,0:POKE 89,RT+5:GOSUB 2000 209 REM DRAW 4TH EVEN FRAME 210 POKE 88,0:POKE 89,RT+6:I=10:GOSUB 1000 219 REM DRAW 4TH ODD FRAME 220 POKE 88,0:POKE 89,RT+7:GOSUB 2000 249 REM DLIST= DISPLAY LIST ADDRESS 250 DLIST=PEEK(560)+256*PEEK(561) 258 REM ASSIGN ADDRESS OF 1ST LINE 259 REM OF DISPLAY DATA IN DLIST TO SCREEN MEMORY 260 POKE 88,PEEK(DLIST+4):POKE 89,PEEK(DLIST+5) 278 REM ASSIGN 0 TO MSB OF ADDRESS OF 1ST LINE 279 REM OF DISPLAY DATA IN DLIST 280 POKE DLIST+4,0 288 REM ASSIGN THE BEGINNING OF RESERVED MEMORY + INCREMENT TO LSB 289 REM OF ADDRESS OF 1ST LINE OF DISPLAY DATA IN DLIST 290 POKE DLIST+5,RT:GOSUB 3000 300 POKE DLIST+5,RT+1:GOSUB 3000 310 POKE DLIST+5,RT+2:GOSUB 3000 320 POKE DLIST+5,RT+3:GOSUB 3000 330 POKE DLIST+5,RT+4:GOSUB 3000 340 POKE DLIST+5,RT+5:GOSUB 3000 350 POKE DLIST+5,RT+6:GOSUB 3000 360 POKE DLIST+5,RT+7:GOSUB 3000 370 GOTO 290 999 REM PRINT ANIMATION EVEN FRAME 1000 POSITION 0,0 1010 ? #6;I$(I*3-2,I*3) 1020 ? #6;I$((I+1)*3-2,(I+1)*3) 1030 ? #6;I$((I+2)*3-2,(I+2)*3) 1050 RETURN 1999 REM PRINT ANIMATION ODD FRAME 2000 POSITION 0,0 2010 ? #6;P$(I*3-2,I*3) 2020 ? #6;P$((I+1)*3-2,(I+1)*3) 2030 ? #6;P$((I+2)*3-2,(I+2)*3) 2050 RETURN 2999 REM PAUSE LOOP 3000 FOR P=1 TO 200:NEXT P:RETURN Regards, Luis. Edited May 26 by lbaeza Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted May 27 Share Posted May 27 On 5/25/2024 at 11:47 PM, lbaeza said: Another question: Am I forced to reserve memory for a full GRAPHICS 2 screen, even though I am only changing the first 3 lines between animation frames? You could use a modified Display list to do a LMS for the top 3 lines from different memory locations, and then another LMS at line 4 for the rest of the screen at a fixed address , but setting this up for the display may prove quite complex. Quote Link to comment Share on other sites More sharing options...
+DjayBee Posted May 27 Share Posted May 27 1 hour ago, TGB1718 said: LMS at line 4 for the rest of the screen at a fixed address , but setting this up for the display may prove quite complex. Not necessarily. If you open a GR. 2 screen and do not use its first three lines, you have 60 spare bytes which can be overwritten with modified DL-bytes. Just edit the automatically created DL using POKES. Its address can be found with PEEK(561)*256+PEEK(560). 1 Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted May 27 Share Posted May 27 This is a modified version that only uses 3 screens to get the same effect. Occasionally you might see some flicker, this is due to poking the new line addresses in BASIC, to eliminate this, you would normally update Display Lists in a VBI routine. 1 DIM I$(36):I$=" ":I$(36)=" ":I$(2)=I$:DIM P$(36):P$=" ":P$(36)=" ":P$(2)=P$ 2 I$="A b d Cd A C bC d b Ab C A d":P$=" A d b C d C A b C b d A b A C d " 3 DIM D(8):GOSUB 4000 4 POSITION 0,6:? #6;"THIS IS FIXED" 5 MYDL=1536+4:MYDH=1536+5 6 DLS=1536+9:DLH=1536+10 20 GOSUB 5000 30 DL=PEEK(560)+PEEK(561)*256 66 TDS=PEEK(DL+4)+PEEK(DL+5)*256:TDS=TDS+60 67 TDH=INT(TDS/256):TDL=INT((TDS/256-TDH)*256) 68 POKE DLS,TDL:POKE DLH,TDH 70 POKE 560,0:POKE 561,6 100 FOR I=0 TO 7 110 Z=D(I):GOSUB 4200 115 POSITION 0,8:? #6;"SCREEN ";I 120 GOSUB 3000 130 NEXT I 140 GOTO 100 999 REM PRINT ANIMATION EVEN FRAME 1000 REM POSITION 0,0 1010 ? #6;I$(I*3-2,I*3) 1020 ? #6;I$((I+1)*3-2,(I+1)*3) 1030 ? #6;I$((I+2)*3-2,(I+2)*3) 1050 RETURN 1999 REM PRINT ANIMATION ODD FRAME 2000 REM POSITION 0,0 2010 ? #6;P$(I*3-2,I*3) 2020 ? #6;P$((I+1)*3-2,(I+1)*3) 2030 ? #6;P$((I+2)*3-2,(I+2)*3) 2050 RETURN 2999 REM PRINT ALL LINES ON 2 SCREENS 3000 FOR J=0 TO 200:NEXT J:RETURN 4000 GRAPHICS 2+16:POSITION 0,0 4010 I=1:GOSUB 1000:GOSUB 2000:I=4:GOSUB 1000:GOSUB 2000 4020 FOR K=0 TO 3 4029 REM SAVE 3 LINE ADDRESSES 4030 D(K)=(PEEK(88)+PEEK(89)*256)+(K*60) 4040 NEXT K 4060 POKE 106,PEEK(106)-2:GRAPHICS 2+16 4065 I=7:GOSUB 1000:GOSUB 2000:I=10:GOSUB 1000:GOSUB 2000 4070 FOR K=0 TO 3 4079 REM SAVE 3 LINE ADDRESSES 4080 D(K+4)=(PEEK(88)+PEEK(89)*256)+(K*60) 4090 NEXT K 4091 REM FINAL SCREEN FOR NOMAL TEXT 4095 POKE 106,PEEK(106)-2:GRAPHICS 2+16 4100 RETURN 4199 REM POKE DL WITH LINE START ADDRESS 4200 DLHI=INT(Z/256):DLLO=INT(((Z/256)-DLHI)*256) 4210 POKE MYDL,DLLO:POKE MYDH,DLHI 4230 RETURN 4999 REM READ IN DISPLAY LIST 5000 RESTORE 10030:I=0 5010 READ A:IF A=-1 THEN 5030 5020 POKE 1536+I,A:I=I+1:GOTO 5010 5030 RETURN 10000 REM MY DISPLAY LIST,PAGE 6 10030 DATA 112,112,112,71,112,154,7,7,71,172 10040 DATA 154,7,7,7,7,7,7,7,7,7 10050 DATA 65,0,6,-1 MYFLIP.BAS 1 Quote Link to comment Share on other sites More sharing options...
