"Tall sprites" question, best practice...
Hey All!
I have a game that uses 'set' sprites in each DL, meaning that (for speed in execution), all sprites are already defined in the DL and they are just moved on and off the screen, depending on their vertical position. (This is so the High Sprite Address and the Horizontal Position are the only two things changed in each DL for each frame).
This game is using twelve 16-high DLs.
However, I am running into an issue:  I have some sprites that are 48 scanlines high, and they need to use the same DL 'slot' for each zone.  Is there a sneaky way to do this?  When I did Bentley Bear's Crystal Quest, for the 32 scanline high sprites (like the player) I used the entire $4000-$7FFF area for the sprite definitions...  blacking out above and below, and not using 'holey' DMA.  I'd rather not waste ROM space for that this time.
Any thoughts?
Thanks!
Bob
Edited by PacManPlus
It's not an answer to your question, but when you used cart RAM before how did you pack the graphics in? Rather than blanking out both top and bottom as would be the case with holey DMA I've found it much more efficient to duplicate some of the graphics so as you offset them MARIA will just fill the gaps with what you want to draw anyway. This way you don't need to double-up DL entries for objects when vertically scrolling like you would 'normally'. It's allowed me to pack way more on screen than I otherwise could and with a big performance boost.
  • Like 4
Hey Bob, I don't think there's a way to have your cake and eat it here. If you want to use DMA holes to preserve graphic rom space (i.e. doing things the usual way) you'll need to use 2 objects in each DL for each of your tall sprites. So 2 "slots" in each zone, per sprite, to use your wording, which also means twice the sprite updates per zone.
1 hour ago, SmittyB said:
[...] I've found it much more efficient to duplicate some of the graphics so as you offset them MARIA will just fill the gaps with what you want to draw anyway. This way you don't need to double-up DL entries for objects when vertically scrolling like you would 'normally'. It's allowed me to pack way more on screen than I otherwise could and with a big performance boost.
It's a great technique. :thumbsup:  I think that's essentially what Bob is referring to with his approach with Bentley Bear... it sounds like he drew the whole tallsprite at the same byte offset across several graphic blocks, and only added transparent padding above the top sprite graphic and below the bottom sprite graphic.
Posted (edited)
Yeah, that's what I was afraid of.  I was playing around with High Address offsets and placements, and couldn't get anything workable. :(
That's exactly what I did... Wish I was better at explaining things 😕 Unfortunately there's all that 'blank space' though above and below the actual sprites...  It's kind of a waste to me...
Thanks guys!
If that memory isn't ever looked at by the DMA and transferred to the screen, you could put small subroutines there.
Could you use regular DMA for the interior parts of the 48px high sprite, and holey DMA for just the top and bottom?
The 'holeyness' would of course affect everything else in the same display list zone, so it wouldn't work if you have multiple 48px high sprites with overlapping and different Y positions...
Edited by Ben_Larson
I actually do this with PMC 40th :)
14 hours ago, Ben_Larson said:
...so it wouldn't work if you have multiple 48px high sprites with overlapping and different Y positions...
Which I actually do (six of them) :(
Thanks guys!
Dynamic Display List is the only way :D
But I would like to mention about something else.
You can modify DL entry any time on the screen, all you need is waiting 7 cycles after WSYNC to make sure that your changes will not affect current LineRAM
Bellow small example of just ONE DL entry 16 line height repeated every zone .
I'm changing only x pos, but you can do this same with low/high address, pallet, width
I found it several uses for demo effect, but someone may find useful for game?
  • Like 5
