Floppy disk stuck in drive
How hard would it be to take the metal cover off of a floppy disk drive?  I have a disk stuck in my internal drive on my STFm.  I have a feeling that the metal piece that slides back and forth on the floppy is the culpret.
I could try and slide something in either above or below the floppy but don't know if I have something thin enough but sturdy enough to work.
Edited by djglish
Forgot to add info
I was able to get the floppy drive top off and the sliding metal piece was sprung and catching on the bottom of the drive innards.  I was able to cut a piece of very thin plastic about 2" wide and get it on top of the metal piece and then the floppy came out.
Put everything back together and it works like it was new.  I guess I'll check the floppy disks closer before putting them in the drive.
It was a blank disk.  I was going through a bunch of disks to see what was on then (not labeled, of course).  I just tossed it since I have hundreds of 3.5" disks.
Going through the ST disks and my 8-bit disks is going to be my winter project.
