I am trying to change the shape/colour of 1 (floor/wall) character for each level of a game so that each level has a different look.
I was hoping to do this by having a character definition for each level via BITMAP or DATA BYTE statements, and then using VARPTR to specify the start-point - but so far all my attempts to achieve this have failed.
1. I couldn't work out how to use VARPTR with BITMAP definitions (i.e. how to get the BITMAP data into an array?).
2. I tried to READ BYTE the definitions (i.e. 32 bytes for 4 characters) from a DATA BYTE table into an ARRAY and then specify 'DEFINE CHAR 97,1,VARPTR ARRAY(LevelNum*8)' to load the appropriate definition at the start of each level - but this did not work (the resulting 'a' looked nothing like the data!).
Can anyone provide a small example of how this should be done?
Edited by chalkyw64
Change 'A' to 'a'
https://forums.atariage.com/topic/371532-define-charcolor-with-varptr-how/
It is actually relatively easy.
I made this example using two characters redefined between two levels.
	' Using VARPTR to redefine graphics for levels
	' by Oscar Toledo G.
	' https://nanochess.org/
	' Creation date: Aug/26/2024.
	level = 1
	WHILE 1
		CLS
		DEFINE CHAR 128,2,VARPTR level_bitmaps((level - 1) * 16)	' Each character is 8 bytes. 2*8 = 16
		DEFINE COLOR 128,2,VARPTR level_colors((level - 1) * 16)	' Each character is 8 bytes. 2*8 = 16
		FOR c = 1 TO 10
			PRINT AT RANDOM(768),"\128"
		NEXT c
		FOR c = 1 TO 10
			PRINT AT RANDOM(768),"\129"
		NEXT c
		FOR c = 1 TO 120: WAIT: NEXT
		level = level + 1
		IF level = 3 THEN level = 1
	WEND
level_bitmaps:
	BITMAP "..XXXX.."
	BITMAP ".X....X."
	BITMAP "X.X..X.X"
	BITMAP "X......X"
	BITMAP "X.X..X.X"
	BITMAP "X..XX..X"
	BITMAP ".X....X."
	BITMAP "..XXXX.."
        BITMAP ".....X.."
	BITMAP "....XXXX"
	BITMAP "XX..X.XX"
	BITMAP ".XXXXXXX"
	BITMAP "..XXXX.."
	BITMAP ".XXXXX.."
	BITMAP ".XX..XX."
	BITMAP ".XX..XX."
	BITMAP "..XXXX.."
	BITMAP ".X....X."
	BITMAP "X......X"
	BITMAP "X.X..X.X"
	BITMAP "X......X"
	BITMAP "X......X"
	BITMAP ".X....X."
	BITMAP "..XXXX.."
        BITMAP "..X..X.."
	BITMAP ".XX..XX."
	BITMAP ".XXXXXX."
	BITMAP ".X.XX.X."
	BITMAP ".XXXXX.X"
	BITMAP "..XXXX.X"
	BITMAP ".XX.XXXX"
	BITMAP ".XX.XXXX"
level_colors:
	DATA BYTE $A1,$A1,$A1,$A1,$A1,$A1,$A1,$A1
	DATA BYTE $31,$31,$31,$31,$31,$31,$31,$31
	DATA BYTE $91,$91,$91,$91,$91,$91,$91,$91
	DATA BYTE $51,$51,$51,$51,$51,$51,$51,$51
