CPUWIZ Posted August 26 Share Posted August 26 Super simple mod I made when the screws came out. I will post the LED voltage specs later, need to pull out the LED drawers. IMG_7931.mov 8 Quote Link to comment Share on other sites More sharing options...
CPUWIZ Posted August 26 Author Share Posted August 26 Weird, I saw this. Quote Link to comment Share on other sites More sharing options...
+sramirez2008 Posted August 27 Share Posted August 27 1 hour ago, CPUWIZ said: Super simple mod I made when the screws came out. I will post the LED voltage specs later, need to pull out the LED drawers. IMG_7931.mov 53.81 MB · 5 downloads This looks great. 👍🏼 Quote Link to comment Share on other sites More sharing options...
+Fred_M Posted August 27 Share Posted August 27 1 hour ago, CPUWIZ said: Weird, I saw this. I see this 😃 It looks amazing! Please tell us how to do this mod 👍 2 1 Quote Link to comment Share on other sites More sharing options...
CPUWIZ Posted August 27 Author Share Posted August 27 Just now, Fred_M said: It looks amazing! Please tell us how to do this mod 👍 Thanks, I'll post exact instructions and the LED specification later, I am kind of busy with a soldering iron at the moment. 3 Quote Link to comment Share on other sites More sharing options...
Maztr_0n Posted August 27 Share Posted August 27 3 hours ago, CPUWIZ said: Thanks, I'll post exact instructions and the LED specification later, I am kind of busy with a soldering iron at the moment. Hmmmmmmmm Quote Link to comment Share on other sites More sharing options...
+D Train Posted August 27 Share Posted August 27 coooooooooooooool. Quote Link to comment Share on other sites More sharing options...
CPUWIZ Posted August 27 Author Share Posted August 27 Ok, here you go, remove the 2 screws, pop the cap and replace the LED. The Anode (longer leg) goes to RED. Old LED below, mine was installed incorrectly from the factory, they clamped the legs instead of the 5mm dome. The clamp is designed to hold the dome in place and center it properly. 3 4 Quote Link to comment Share on other sites More sharing options...
+Fred_M Posted August 27 Share Posted August 27 2 hours ago, CPUWIZ said: Ok, here you go, remove the 2 screws, pop the cap and replace the LED. The Anode (longer leg) goes to RED. Old LED below, mine was installed incorrectly from the factory, they clamped the legs instead of the 5mm dome. The clamp is designed to hold the dome in place and center it properly. Thanks! I was hoping it would be just replacing the LED 😃 This is an easy job, ordering the led now 😁 It looks like my LED was fitted correctly. 1 Quote Link to comment Share on other sites More sharing options...
TheRingBearer Posted August 27 Share Posted August 27 13 hours ago, CPUWIZ said: exact instructions and the LED specification later Are these slow or fast flashing LEDs? 1 Quote Link to comment Share on other sites More sharing options...
tradyblix Posted August 27 Share Posted August 27 14 hours ago, CPUWIZ said: Super simple mod I made when the screws came out. I will post the LED voltage specs later, need to pull out the LED drawers. IMG_7931.mov 53.81 MB · 17 downloads That's cool !!! Man I want that. You can't do that with a 7800+ (you probably could, just saying) Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted August 27 Share Posted August 27 @CPUWIZ That was the first thing I did within 30min of opening my 2600+. I have a bunch of slow changing RGBs and just swapped it right in and been using it that way ever since. 1 Quote Link to comment Share on other sites More sharing options...
CPUWIZ Posted August 27 Author Share Posted August 27 2 minutes ago, -^CrossBow^- said: @CPUWIZ That was the first thing I did within 30min of opening my 2600+. I have a bunch of slow changing RGBs and just swapped it right in and been using it that way ever since. GMTA Quote Link to comment Share on other sites More sharing options...
+sramirez2008 Posted August 28 Share Posted August 28 17 hours ago, CPUWIZ said: Ok, here you go, remove the 2 screws, pop the cap and replace the LED. The Anode (longer leg) goes to RED. Old LED below, mine was installed incorrectly from the factory, they clamped the legs instead of the 5mm dome. The clamp is designed to hold the dome in place and center it properly. Too cool for school. Ordered! Thanks for sharing.👍 Quote Link to comment Share on other sites More sharing options...
+Fred_M Posted August 28 Share Posted August 28 On 8/27/2024 at 12:19 PM, CPUWIZ said: Ok, here you go, remove the 2 screws, pop the cap and replace the LED. The Anode (longer leg) goes to RED. Old LED below, mine was installed incorrectly from the factory, they clamped the legs instead of the 5mm dome. The clamp is designed to hold the dome in place and center it properly. Thank you @CPUWIZ 😃 2600plus_led.mp4 3 Quote Link to comment Share on other sites More sharing options...
tradyblix Posted August 28 Share Posted August 28 So uh.... thinking about doing this when I repace the slot board. Where can I get the correct color changing LED from ? Quote Link to comment Share on other sites More sharing options...
+Fred_M Posted August 28 Share Posted August 28 5 hours ago, tradyblix said: So uh.... thinking about doing this when I repace the slot board. Where can I get the correct color changing LED from ? From any (web) store that sells electronic components. Just do an online search for color changing LED 3v. It will cost less than a dollar. I can give you the link to the store I bought it from, but it is in The Netherlands so it will probably not help you 😉 3 Quote Link to comment Share on other sites More sharing options...
T.Bone Posted August 28 Share Posted August 28 4 hours ago, Fred_M said: From any (web) store that sells electronic components. Just do an onle search for color changing LED 3v. It will cost less than a dollar. I can give you the link to the store I bought it from, but it is in The Netherlands so it will probably not help you 😉 Thanks for the info I'll be ordering mine also. Can't wait til the 2600+ arrives. Quote Link to comment Share on other sites More sharing options...
