larsvonhier Posted October 3 Share Posted October 3 Hi @Ben from Plaion, any PCBs left? I start to have increasingly more dumper problems probably due to bad contacts... Quote Link to comment https://forums.atariage.com/topic/371614-updated-cartridge-socket-giveaway/page/11/#findComment-5543084 Share on other sites More sharing options...
larsvonhier Posted October 3 Share Posted October 3 1 hour ago, larsvonhier said: Hi @Ben from Plaion, any PCBs left? I start to have increasingly more dumper problems probably due to bad contacts... Edit. Photo attached. Quote Link to comment https://forums.atariage.com/topic/371614-updated-cartridge-socket-giveaway/page/11/#findComment-5543103 Share on other sites More sharing options...
MarcinJ Posted October 3 Share Posted October 3 (edited) I am still waiting for mine to arrive. 🧐 Hopefully it did not get stuck in some customs. Edited October 3 by MarcinJ 1 Quote Link to comment https://forums.atariage.com/topic/371614-updated-cartridge-socket-giveaway/page/11/#findComment-5543104 Share on other sites More sharing options...
MrChickenz Posted October 3 Share Posted October 3 49 minutes ago, MarcinJ said: I am still waiting for mine to arrive. 🧐 Hopefully it did not get stack in some customs. I am waiting for mine as well. 1 Quote Link to comment https://forums.atariage.com/topic/371614-updated-cartridge-socket-giveaway/page/11/#findComment-5543118 Share on other sites More sharing options...
Ben from Plaion Posted October 3 Author Share Posted October 3 (edited) 12 hours ago, nopaybob said: New socket but it's soldered on upside down I was wandering what the heck I was doing wrong because it wouldn't go back together right. The top pcb is the new one. oh for the love of god! Edited October 3 by Ben from Plaion 1 Quote Link to comment https://forums.atariage.com/topic/371614-updated-cartridge-socket-giveaway/page/11/#findComment-5543147 Share on other sites More sharing options...
Ben from Plaion Posted October 3 Author Share Posted October 3 11 hours ago, Commander Grog said: Just as a litte status report: I now (don't judge, I'm a little...uhm...thorhough) have tested all my 82 2600 games and everyhing works perfectly. The grip of the slot is pretty tight, but that might change after some use. Thats what I want to hear, thanks for your thorough testing! 1 Quote Link to comment https://forums.atariage.com/topic/371614-updated-cartridge-socket-giveaway/page/11/#findComment-5543148 Share on other sites More sharing options...
Striker667xbl Posted October 3 Share Posted October 3 14 hours ago, Commander Grog said: Just as a litte status report: I now (don't judge, I'm a little...uhm...thorhough) have tested all my 82 2600 games and everyhing works perfectly. The grip of the slot is pretty tight, but that might change after some use. That should help with keeping the cart pins clean! 👍 Quote Link to comment https://forums.atariage.com/topic/371614-updated-cartridge-socket-giveaway/page/11/#findComment-5543218 Share on other sites More sharing options...
Thomas Jentzsch Posted October 3 Share Posted October 3 16 hours ago, nopaybob said: New socket but it's soldered on upside down I was wandering what the heck I was doing wrong because it wouldn't go back together right. The top pcb is the new one. Are they soldered by hand? Or how can this happen? 1 Quote Link to comment https://forums.atariage.com/topic/371614-updated-cartridge-socket-giveaway/page/11/#findComment-5543257 Share on other sites More sharing options...
xeex Posted October 3 Share Posted October 3 Received today. Socket soldered correctly. Thank you very much, Ben! 1 Quote Link to comment https://forums.atariage.com/topic/371614-updated-cartridge-socket-giveaway/page/11/#findComment-5543275 Share on other sites More sharing options...
nopaybob Posted October 3 Share Posted October 3 1 hour ago, Thomas Jentzsch said: Are they soldered by hand? Or how can this happen? Here's a pic of the the backside. 2 Quote Link to comment https://forums.atariage.com/topic/371614-updated-cartridge-socket-giveaway/page/11/#findComment-5543294 Share on other sites More sharing options...
+-^CrossBow^- Posted October 3 Share Posted October 3 17 hours ago, nopaybob said: New socket but it's soldered on upside down I was wandering what the heck I was doing wrong because it wouldn't go back together right. The top pcb is the new one. If it were me...instead of desoldering the port to swap it around, I would just use my x-acto or other sharp hobby knife and remove the excess plastic around the base. The port it self is still centered the issue is the plastic on the base prevents it from seating back into the cartridge molded sleeve on the bezel portion. So, yeah, I would just try and cut and remove that excess plastic. You won't see any of it anyway once it is all back together. I installed mine last night, but as I had the older style it was a right bear to do and I basically had to remove every single screw and completely remove the bezel around the switches etc. It was.... interesting to hold that stuff into place manually while trying to get some of the screws back in afterwards. Also the ribbon cables had to be twisted of course to match up, but also they are just about long enough to reach so there isn't must play in the ribbons to move them where needed. 3 Quote Link to comment https://forums.atariage.com/topic/371614-updated-cartridge-socket-giveaway/page/11/#findComment-5543299 Share on other sites More sharing options...
MrChickenz Posted October 3 Share Posted October 3 (edited) 18 hours ago, nopaybob said: New socket but it's soldered on upside down I was wandering what the heck I was doing wrong because it wouldn't go back together right. The top pcb is the new one. Games like Galaxian or Pitfall! might be a problem but you should be able to play Asteroids with no issues! 😄 Edited October 3 by MrChickenz 1 14 Quote Link to comment https://forums.atariage.com/topic/371614-updated-cartridge-socket-giveaway/page/11/#findComment-5543309 Share on other sites More sharing options...
JetmanUK Posted October 3 Share Posted October 3 23 minutes ago, MrChickenz said: Games like Galaxian or Pitfall! might be a problem but you should be able to play Asteroids with no issues! 😄 Ah Fall Pit, a classic. 5 Quote Link to comment https://forums.atariage.com/topic/371614-updated-cartridge-socket-giveaway/page/11/#findComment-5543319 Share on other sites More sharing options...
Ben from Plaion Posted October 3 Author Share Posted October 3 1 hour ago, nopaybob said: Here's a pic of the the backside. I'm back in the office Monday and can send you another no worries, I'll double check the cart positioning but pretty sure what you got was a one off human error. EVery single 2600+ manufactured has a final cart insertion and diagnostic check....these IO PCBs I've given away have been likely hand made and the guy doing them just messed yours up. 4 Quote Link to comment https://forums.atariage.com/topic/371614-updated-cartridge-socket-giveaway/page/11/#findComment-5543330 Share on other sites More sharing options...
Ben from Plaion Posted October 3 Author Share Posted October 3 (edited) One thing to note people that have received the update cartridge socket boards, I didnt check what dumper version was flashed to the MCU, so you might want to check that if you're on anything other then 1.0 firmware. Edited October 3 by Ben from Plaion 3 4 Quote Link to comment https://forums.atariage.com/topic/371614-updated-cartridge-socket-giveaway/page/11/#findComment-5543337 Share on other sites More sharing options...
Ben from Plaion Posted October 3 Author Share Posted October 3 28 minutes ago, JetmanUK said: Ah Fall Pit, a classic. I mean I laughed and then said FFS 1 Quote Link to comment https://forums.atariage.com/topic/371614-updated-cartridge-socket-giveaway/page/11/#findComment-5543341 Share on other sites More sharing options...
JetmanUK Posted October 3 Share Posted October 3 Just now, Ben from Plaion said: I mean I laughed and then said FFS The kinda reaction I like. 😎 2 Quote Link to comment https://forums.atariage.com/topic/371614-updated-cartridge-socket-giveaway/page/11/#findComment-5543342 Share on other sites More sharing options...
+bent_pin Posted October 3 Share Posted October 3 2 minutes ago, Ben from Plaion said: 31 minutes ago, JetmanUK said: Ah Fall Pit, a classic. I mean I laughed and then said FFS Ahem 3 Quote Link to comment https://forums.atariage.com/topic/371614-updated-cartridge-socket-giveaway/page/11/#findComment-5543345 Share on other sites More sharing options...
Ben from Plaion Posted October 3 Author Share Posted October 3 Just now, bent_pin said: Ahem Jesus Christ, another meme in the making 2 Quote Link to comment https://forums.atariage.com/topic/371614-updated-cartridge-socket-giveaway/page/11/#findComment-5543346 Share on other sites More sharing options...
+bent_pin Posted October 3 Share Posted October 3 6 minutes ago, bent_pin said: 9 minutes ago, Ben from Plaion said: 38 minutes ago, JetmanUK said: Ah Fall Pit, a classic. I mean I laughed and then said FFS Ahem 5 minutes ago, Ben from Plaion said: Jesus Christ, another meme in the making Staring Ryan Gosling 1 Quote Link to comment https://forums.atariage.com/topic/371614-updated-cartridge-socket-giveaway/page/11/#findComment-5543350 Share on other sites More sharing options...
Ben from Plaion Posted October 3 Author Share Posted October 3 1 hour ago, bent_pin said: Staring Ryan Gosling I'd watch him tarzanning some vines and jumping on crocodiles backs....upside down! 3 Quote Link to comment https://forums.atariage.com/topic/371614-updated-cartridge-socket-giveaway/page/11/#findComment-5543380 Share on other sites More sharing options...
Striker667xbl Posted October 4 Share Posted October 4 4 hours ago, Ben from Plaion said: I'm back in the office Monday and can send you another no worries, I'll double check the cart positioning but pretty sure what you got was a one off human error. EVery single 2600+ manufactured has a final cart insertion and diagnostic check....these IO PCBs I've given away have been likely hand made and the guy doing them just messed yours up. Well.. If your looking for somewhere to put that mistake pcb... I've got a soldering station and a lot of desoldering braid..I'm just saying 😉 hehe. 1 Quote Link to comment https://forums.atariage.com/topic/371614-updated-cartridge-socket-giveaway/page/11/#findComment-5543459 Share on other sites More sharing options...
JetmanUK Posted October 4 Share Posted October 4 12 hours ago, bent_pin said: Ahem I wanna play Fall Pit! 1 Quote Link to comment https://forums.atariage.com/topic/371614-updated-cartridge-socket-giveaway/page/11/#findComment-5543571 Share on other sites More sharing options...
Plumbob Posted October 4 Share Posted October 4 (edited) Received and installed mine yesterday. Thanks @Ben from Plaion! Due to tolerance stack on my particular 2600+, I found that it was necessary to file down some of the plastic ridge, as shown here so that the edge of this capacitor could clear the plastic ridge while installing the new PCB. Until I did this, I couldn’t get it put back together. I only mention this incase it is helpful to other people. Edited October 4 by Plumbob Clarity 3 2 Quote Link to comment https://forums.atariage.com/topic/371614-updated-cartridge-socket-giveaway/page/11/#findComment-5543626 Share on other sites More sharing options...
DhaemonX Posted October 4 Share Posted October 4 The PCB came to my wife's work today. I'll tackle it later. Can't wait to dig in. Anyone know what dumper version is on it? Quote Link to comment https://forums.atariage.com/topic/371614-updated-cartridge-socket-giveaway/page/11/#findComment-5543657 Share on other sites More sharing options...
