ftdi232 Posted September 3 Share Posted September 3 Hello everyone. I'm planning on building the Sound Enhancer by chart45 for my ADAM and have a couple of questions. First, I would like to have audio out directly from the Sound Enhancer. From what I understand, I can get audio from pin 31 on the edge connector but which pin is ground? Also, is the led a 3mm or 5mm? I'm assuming that the led is 5V. Any help would be appreciated. Thanks. Quote Link to comment Share on other sites More sharing options...
NIAD Posted September 4 Share Posted September 4 Mozzwald of the FujiNet Team could answer these questions as he made a number of production runs of the ADAM Sound Enhancer with a sound output port, power LED and case. The sound port is great because one doesn't have to open up the ADAM to fix Coleco incorrectly tapping sound on the ADAM Logic Board which causes low volume output to any sound device that one connects to the Expansion Interface. Check out the FujiNet Discord site seeing as he is very active on there. Quote Link to comment Share on other sites More sharing options...
ftdi232 Posted September 4 Author Share Posted September 4 Thank you for the information. Not having to modify the ADAM board is the main reason for building the Sound Enhancer. I will try to get in touch with Mozzwald. Quote Link to comment Share on other sites More sharing options...
