netrogames Posted September 11 Share Posted September 11 This eBay auction had no controllers. I thought that was kind of cool because I could use my flashback controllers along with these flashback adapters I got from 8bitwidgets.com to play The Flashback Controllers on an intellivision 2. Does Sears have the exact same layout as the intellivision 2 9 pin? I noticed some weird behavior In ladybug it would not let me go beyond the title screen despite pressing all the number buttons. In Astro Smash pushing the disc made it go into a game where the game started but I can't move anywhere. Also 0 fires, and the clear button teleports. That was when I tried it with the flashback controllers plugged into the 8-bit widget device. I thought maybe it was modified to be flashback modded so I tried the flashback plugs directly. As it turned out those didn't work either. My only thought was that if it was made to be a logical controller, someone modded it to work with some other kind of controller that was DB9 either Atari or Odyssey or Astrocade or Genesis. I could try three of the four of them and see if those work. But other than that I can't explain the behavior of the controls that I had before that were working perfectly fine on an intellivision one, and flashback mods purchased when the Flashbacks were out, but have strange behavior in this new Sears Intellivision. I'm seeing if the previous owner was a previous owner or whether he just got something that was in trade and never tested. He said tested but it's guaranteed. I'll see what the eBay seller says tomorrow if he had a history with it or not. Otherwise what could explain that? By the way this is the flashback adapter I bought from 8-bit widgets and I don't know whether the 8-bit widgets device doesn't work or whether the console I got was modded or not. Quote Link to comment Share on other sites More sharing options...
CharonPDX Posted September 20 Share Posted September 20 Sears and Inty2 are compatible/same pinout. I regularly use Sears controllers on my Inty2, and have tested Inty2 on Sears successfully. (I even bought a second set of Sears controllers off eBay to have spares/specifically to use on Inty2.) I have no idea about the use of Flashback adapters. I've only ever used the other way around (adapter that lets me use real Sears/Inty2 controller on a Flashback.) 2 Quote Link to comment Share on other sites More sharing options...
Crash7 Posted September 20 Share Posted September 20 Yes 8bit has an adapter where you can use flashbacks on the Sears console Quote Link to comment Share on other sites More sharing options...
netrogames Posted 4 hours ago Author Share Posted 4 hours ago As it turned out, it's a Reverse Adapter. It was originally packaged as a INTVFB controller to INTV2. controller. Just changing the genders with a double male DB9 and a double female DB9 and reversing the direction of installation made it work. Quote Link to comment Share on other sites More sharing options...
