Atari ST MIDI Files in 8.3 format reads properly on the Atari ST
Hi,
Is your end goal to create .ST or .MSA images that you can then write to floppy disks so the ST can read them? (or Gotek perhaps?). If yes then you could use something like MSA converter (http://msaconverter.free.fr/index-uk.html). Or of course use an emualtor and copy the files to .ST/.MSA images via GEM or a copy program (although this is more cumbersome).
3 hours ago, ggn said:
Hi,
Actually I set up a hard drive in Steem and just use them the way they are , Steem reads them fine , and if someone is using an actual hard drive they can just copy the zip file the way it is and put he MIDI files in a folder just the way that they are.
Hi,
Yes I could make them all available via .MSA or .ST, that is no real problem except that you may end up with 12 plus disks to span the entire library.
