Does the console ROM have an inverse to CFI? An int to float routine, instead of float to int?
jedimatt42
I've got code... but if the console ROM has callable code, I'd rather do that.
I'm not seeing anything, but I wouldn't be surprised if user input always starts as a string, converted to a float, instead of ever needing to go directly from int to float.
Extended Basic ROM has CIF and CFI, it does use the Console ROM for part of the CFI
2739 74AA              AORG >74AA
  2741
  2742            ************************************************************
  2743            * CIF     - Convert integer to floating
  2744            *           Assume that the value in the FAC is an integer
  2745            *            and converts it into an 8 byte floating point
 99/4 ASSEMBLER
CIFS                                                         PAGE 0063
  2746            *            value
  2747            ************************************************************
  2748 74AA 0204  CIF    LI   R4,FAC            Will convert into the FAC
       74AC 834A
  2749 74AE C014         MOV  *R4,R0            Get integer into register
  2750 74B0 C184         MOV  R4,R6             Copy pointer to FAC to clear i
  2751 74B2 04F6         CLR  *R6+              Clear FAC & FAC+1
  2752 74B4 04F6         CLR  *R6+              In case had a string in FAC
  2753 74B6 C140         MOV  R0,R5             Is integer equal to zero?
  2754 74B8 1323         JEQ  CIFRT             Yes, zero result and return
  2755 74BA 0740         ABS  R0                Get ABS value of ARG
  2756 74BC 0203         LI   R3,>40            Get exponent bias
       74BE 0040
  2757 74C0 04F6         CLR  *R6+              Clear words in result that
  2758 74C2 04D6         CLR  *R6                might not get a value
  2759 74C4 0280         CI   R0,100            Is integer less than 100?
       74C6 0064
  2760 74C8 1A13         JL   CIF02             Yes, just put in 1st fraction
  2761            *                              part
  2762 74CA 0280         CI   R0,10000          No, is ARG less then 100^2?
       74CC 2710
  2763 74CE 1A08         JL   CIF01             Yes, just 1 division necessary
  2764            *                             No, 2 divisions are necessary
  2765 74D0 0583         INC  R3                Add 1 to exponent for 1st
  2766 74D2 C040         MOV  R0,R1             Put # in low order word for th
  2767            *                              divide
  2768 74D4 04C0         CLR  R0                Clear high order word for the
  2769            *                              divide
  2770 74D6 3C20         DIV  @C100,R0          Divide by the radix
       74D8 6008
  2771 74DA D920         MOVB @R1LB,@3(R4)  ~@  Move the radix digit in
       74DC 83E3
       74DE 0003
  2772 74E0 0583  CIF01  INC  R3                Add 1 to exponent for divide
  2773 74E2 C040         MOV  R0,R1             Put in low order for divide
  2774 74E4 04C0         CLR  R0                Clear high order for divide
  2775 74E6 3C20         DIV  @C100,R0          Divide by the radix
       74E8 6008
  2776 74EA D920         MOVB @R1LB,@2(R4)  ~@  Put next radix digit in
       74EC 83E3
       74EE 0002
  2777 74F0 D920  CIF02  MOVB @R0LB,@1(R4)  ~@  Put highest order radix digit
       74F2 83E1
       74F4 0001
  2778 74F6 D520         MOVB @R3LB,*R4         Put exponent in
       74F8 83E7
  2779 74FA 0545         INV  R5                Is result positive?
  2780 74FC 1101         JLT  CIFRT             Yes, sign is correct
  2781 74FE 0514         NEG  *R4               No, make it negative
  2782 7500 045B  CIFRT  RT
  2783            ************************************************************
  2784
CFI     >12B8 is the GPL Console ROM routine used by TI Basic and XB to Convert Floating Point to Integer
Edited by RXB
Spelling
