+Random Terrain Posted Monday at 08:20 AM Share Posted Monday at 08:20 AM Is there a better way to get the distance between two objects than using something like this? if player0y > missile0y then temp6 = player0y - missile0y if missile0y > player0y then temp6 = missile0y - player0y Seems like there would be a fancy math way that doesn't require two if-thens. Quote Link to comment Share on other sites More sharing options...
+splendidnut Posted Monday at 12:54 PM Share Posted Monday at 12:54 PM You might be thinking of the 'absolute value' math function found in most programming languages: temp = abs(player0y - missile0y) Which in bBasic, would be: temp6 = player0y - missile0y if temp6{7} then temp6 = -temp6 ;-- IF value is negative, THEN make it positive. NOTE: If the distance is greater than 127, this doesn't work, since big values would be interpreted as negative values due to the byte range limit. 1 Quote Link to comment Share on other sites More sharing options...
