What is the best bounding box code for two 8x8 sprites?
Random Terrain
I'm working on a DPC+ program and can't rely on normal collision detection since there is a third sprite on the screen.
What is the fastest/smallest bounding box code for two 8x8 sprites that simply uses an if-then or two? I'd like to avoid using data. The code below seems to be working so far, but I don't know if it's the best code to use:
   if !collision(player0,player1) then goto __Skip_Player_Death
   if player1x < (player0x+8) && (player1x+8) > player0x && player1y < (player0y+8) && (player1y+8) > player0y then goto __P0_P1_Collision
Thanks.
3 hours ago, Karl G said:
I'm afraid that your code is as simple as it gets for a box collision like this.  🙂
RevEng posted an assembly "boxcollision" function for bB taken from 7800BASIC that you could use. I don't know if it would be less cycles or not since you also have the overhead of a function call if you use that code.
Thanks. I tried all kinds of things that didn't work, quit and played an Xbox game for a while, then that code popped into my head. I don't even know if it works right in all cases, but it seems to be working somehow. If nobody sees a problem with the code I posted, I guess I'll just stick with that.
