I've looked at all examples and read the manual, I'm just trying to fill the screen with a solid tile but only the sprite shows up, please point out why?
    MODE 0
    DEFINE SPRITE 0, 1, happy_face
    DEFINE CHAR 10, 1, game_bitmaps
    DEFINE COLOR 10 ,1 , game_colors
    player_x = 50
    player_y = 100
    face_color = 10
    #score = 0
    GOSUB update_score
    SCREEN DISABLE
    GOSUB draw_level
    SCREEN ENABLE
game_loop:
    IF cont1.up THEN
        player_y = player_y - 1
    END IF
    IF cont1.down THEN
    player_y = player_y + 1
    END IF
    IF cont1.left THEN
		player_x = player_x - 1
	END IF
    IF cont1.right THEN
       player_x = player_x + 1
    END IF
    SPRITE 0, player_y-1, player_x, 0, face_color
    #score = #score + 1
    GOSUB update_score
    WAIT
    GOTO game_loop
update_score:	PROCEDURE
    PRINT AT 2, #score, "0"
END
draw_level:	PROCEDURE
    'The screen is a 32x24 grid located at the VRAM address $1800-$1aff.
    'It can be accessed using VPOKE (writing) and VPEEK (reading).
    FOR #c = $1800 TO $1aff STEP 1
        VPOKE #c, 10
    NEXT #c
END
happy_face:
    BITMAP "......XXXX......"
    BITMAP "....XXXXXXXX...."
    BITMAP "...XXXXXXXXXX..."
    BITMAP "..XXXXXXXXXXXX.."
    BITMAP ".XXXXXXXXXXXXXX."
    BITMAP "XXXX..XXXX..XXXX"
    BITMAP "XXXXXXXXXXXXXXXX"
    BITMAP ".XXX..XXXX..XXX."
    BITMAP "..XXX......XXX.."
    BITMAP "...XXX....XXX..."
game_bitmaps:
    BITMAP "XXXXXXXX"
    BITMAP "XXXXXXXX"
    BITMAP "XXXXXXXX"
    BITMAP "XXX..XXX"
    BITMAP "XXX..XXX"
    BITMAP "XXXXXXXX"
    BITMAP "XXXXXXXX"
    BITMAP "XXXXXXXX"
game_colors:
    DATA BYTE $16
https://forums.atariage.com/topic/373478-my-cv-basic-questions/
From what I can see, you need to set your colors for each row of pixels in the tile defined in game_bitmaps:
11 hours ago, Lillapojkenpåön said:
game_colors:
    DATA BYTE $16
If you change this to "DATA BYTE $16,$16,$16,$16,$16,$16,$16,$16" you'll have a black screen filled with red dots.
I tried it with both
DEFINE COLOR 10 ,8 , game_colors
and
it compiles successfully but it's still just a black background 😢
and
You used color $16 (this is black for pixels set, and red for pixels clear).
CVBasic clears the memory on start, and you only defined a single DATA BYTE $16. It isn't enough, you need to repeat eight times the value $16.
I've changed that single line and it works just fine (see the screenshot with the DATA BYTE line selected)
CapturadePantalla2024-10-07ala(s)11_38_11.thumb.png.3c8cad1b3fb14861b01c927af00e95f7.png
 Ok thanks, I give up then
Posted (edited)
1 hour ago, nanochess said:
Haha you are doing something incredibly wrong. Do a comparison with this.
Oh, I see what's wrong..
Last time I cd to the examples folder, I forgot this time so my output ended up elsewhere and I was just running the same old rom over and over.
I've never seen a more glorious background in my life 😄
Edited by Lillapojkenpåön
  • Haha 1
2 hours ago, Lillapojkenpåön said:
Is DEFINE CHAR a buffered command with limitations similar to intybasic, once per frame etc.?
No, in CVBasic the data is loaded into the VRAM immediately.
Ony the sprites are buffered like in IntyBASIC.
  • 2 weeks later...
I'm not used to static arrays, is this an acceptable way to create bullets? There seems to be slight slowdown after all 7 possible bullets are on screen, is that just the emulator, my code or some other restriction?
    CONST FALSE = 0
    CONST TRUE = 1
    CONST NOT_IN_USE = 5000
    DIM #bullet_x(7)  : UNSIGNED #bullet_x
    DIM #bullet_y(7)  : UNSIGNED #bullet_y
    FOR temp1 = 0 TO 6
        #bullet_y(temp1) = NOT_IN_USE
        #bullet_x(temp1) = $0000
    NEXT
    'create bullet
    IF CONT1.BUTTON THEN
        IF fire_restrainer = FALSE THEN
            fire_restrainer = TRUE
            FOR temp1 = 0 TO 6
                IF #bullet_y(temp1) = NOT_IN_USE THEN
                    #bullet_y(temp1) = #player_y
                    #bullet_x(temp1) = #player_x
                    'exit loop when free slot is found
                    EXIT FOR
                END IF
            NEXT
        END IF
    ELSE
    END IF
    'move bullets
    FOR temp1 = 0 TO 6
        IF #bullet_y(temp1) <> NOT_IN_USE THEN
            #bullet_x(temp1) = #bullet_x(temp1) + $0100
        END IF
    NEXT
    'reset bullet for re-use when offscreen
    FOR temp1 = 0 TO 6
        IF (#bullet_x(temp1) / 256) >= 255 THEN
        END IF
    NEXT
    'draw bullets starting with sprite 1
    sprite_nr = 1
    FOR temp1 = 0 TO 6
            SPRITE sprite_nr, (#bullet_y(temp1) / 256) - 1, (#bullet_x(temp1) / 256), 0, 10
            sprite_nr = sprite_nr + 1
        ELSE
            SPRITE sprite_nr, 0, 0, 0, 0
        END IF
    NEXT
Also what syntax highlighting does people use when posting basic code on the forum?
20 hours ago, shaoth said:
have you tried to reduce the number of projectiles?
In those days you had to make compromises ;)
I have, there's no slowdown then.. I just really like projectiles 🙂
After compromising as much as I can, and fixing a bug where all bullets collided with all enemies offscreen the slowdown is gone
I'm having a hard time figuring out why this doesn't copy the sprite frame to the buffer like I want it to
        #temp16 = VARPTR player_idle(0)
        #player_buffer(0) = PEEK(#temp16    )
        #player_buffer(1) = PEEK(#temp16 + 1)
        #player_buffer(2) = PEEK(#temp16 + 2)
        #player_buffer(3) = PEEK(#temp16 + 3)
        #player_buffer(4) = PEEK(#temp16 + 4)
        #player_buffer(5) = PEEK(#temp16 + 5)
        #player_buffer(6) = PEEK(#temp16 + 6)
        #player_buffer(7) = PEEK(#temp16 + 7)
        #player_buffer(8) = PEEK(#temp16 + 8)
        #player_buffer(9) = PEEK(#temp16 + 9)
        #player_buffer(10) = PEEK(#temp16 + 10)
        #player_buffer(11) = PEEK(#temp16 + 11)
        #player_buffer(12) = PEEK(#temp16 + 12)
        #player_buffer(13) = PEEK(#temp16 + 13)
        #player_buffer(14) = PEEK(#temp16 + 14)
        #player_buffer(15) = PEEK(#temp16 + 15)
        DEFINE SPRITE 0, 1, VARPTR #player_buffer(0)
All my attempts result in a stripy graphic?
Try using 8-bit variables instead.  Right now your variables are 16 bit, so in binary for example, it's 0000000011010010 per variable and the Colecovision VDP graphic is 8-bit.  I would recommend using 8-bit variables when possible when the z80 processor is 8-bit. The # in front of the variable name tells it that it is 16-bit, which is same for Intybasic. Removing that will make it 8-bit variable.
Edited by Kiwi
Thanks, it's not stripy anymore but the graphic is now only 8 pixels wide instead of 16
EDIT:
Oh!
player_buffer(16) = PEEK(#temp16 + 16)
player_buffer(17) = PEEK(#temp16 + 17)
player_buffer(18) = PEEK(#temp16 + 18)
etc..
is the right side of the graphics, nice!
