pastbytes Posted October 7 Share Posted October 7 A few months ago I decided to connect a few Z80 machines to the internet, starting with the MSX computers, with a wifi modem connected to the printer port, continuing with the Pecos (a computer designed and manufactured in Argentina in the 80s), also through the printer port, and now finishing with the Timex Sinclair 2068, in this case with a wifi modem connected to the joystick port. The goal of this project is to provide minimum connectivity to the network to be able to access BBS in ASCII format. To achieve this we use ESP8266 modules with the zimodem firmware (v3.5.4), and we need the machine to have 2 output pins and one input pin available on some port. The printer ports on the MSX and Pecos meet the requirements because they have 1 input pin and 9 output pins, the joystick port on the TS2068 is bidirectional, but unfortunately it is not programmable by pin but has to be all input or all output at the same time. This made the circuit the most complex of the 3. To test the modem I wrote a minimalist terminal, Microterm, which we usually use for these experiments. Microterm only supports ASCII characters on a 32x24 character screen. To return to BASIC you have to press STOP (Symbol shift + A), and to run the terminal again, RUN 40. On my website you have the instructions (in Spanish) to configure the modem, along with the schematic to assemble it and the link to download the terminal in .tap format. https://youtu.be/ArVEcRkw7eg https://youtu.be/_T5Gv6lvEus https://youtu.be/v2qkbH1V-CY 1 Quote Link to comment Share on other sites More sharing options...
pastbytes Posted October 7 Author Share Posted October 7 https://www.pastbytes.com/wifimodem/#timex 1 Quote Link to comment Share on other sites More sharing options...
r_chase Posted October 11 Share Posted October 11 I would also post about this in the ZX Spectrum thread because I remember that it was originally an attempt to bring the Speccy to North America. Other than that, this seems cool. Quote Link to comment Share on other sites More sharing options...
