Raycaster, first trial
42bs
2 hours ago, agradeneu said:
Lynx has a Math coprocessor, and even the CPU has a higher clock than A8.
The multiplications can likely be done by table look-up. Only the division to get the wall height is time consuming. And of course, SUZY can nicely draw a stripe.
2 hours ago, sage said:
impressed. just so bad that textures in y double the size than x.
I do not understand? You mean this:
It depends on the FOV.
now please add some friendly faces :)
I need to add collision detection first. Currently one can run into a wall.
Plus there are some glitches when you are close to the wall.
No what i mean is that lynx has sprites organized horizontally, thus, size byte plus data byte per line. limits the number of textures in memory by ~2.
i digged not that deeply into the code. do you use blocks or walls between blocks?
Ah, yes, every stripe needs 2 bytes horizontally. Doing it vertical would have some positive effects:
- Drawing is by increasion RAM address.
- Sprite data optimized.
- X resolution only 102 compared to 160
It is blocks. Latest version now checks the side, so every side could have a different texture. This might allow something like door which are on the edge.
Another problem is the limited number of colors. So having many different textures needs a good GFX artist to handle this.
4 minutes ago, LordKraken said:
ok now make the game ;)
Still things to work out:
- collision
- doors
- thin walls
- windows (well low prio)
and essential: sprites (enemies, shots, med packs, ammunition .. ;-) )
Hmm, I could have submitted it as a game to SVWE2024 if only I would have stopped myself from early publishing it.
