5 hours ago, RodLightning said:
This is my go-to program for working on partitions:  MiniTool Partition Wizard Free
https://www.partitionwizard.com/free-partition-manager.html
Thanks, but MiniTool Partition Wizard is telling me I need you upgrade to Pro.  I don't know if it's going to help but I have a dual boot set up on this drive with Windows 10 and Windows 11.
Edited by walter_J64bit
I think the free version of MiniTool no longer does that.  Sorry.
You might try the built in utility in Windows control panel: System and Security-->Administrative Tools-->Create and format hard disk partitions
When you right click on the desired partition, are there options to shrink or extend?
Otherwise,  I know of another tool called Disk Genius.  I recently used it to clone one of my system drives.
https://www.diskgenius.com/manual/resize-partition.php
It has been a while since I have done that but as @RodLightning mentioned you should be able to do it with the built in Windows Disk Manager tool provided you have an administrator account or can otherwise run it as Administrator as I think only Adminstators can change/rename partitions and drives.
