CC9900 Micro Expansion-System Power supply features
Good morning,
I would like to know the intensities that this box consumes on 5 volts and 12 and -12 volts, or if you have a photo of the power supply box label
Merci.
Bonjour,
je désire connaitre les intensités que consomme ce boitier  sur le 5 volts et le 12 et - 12 volts
Edited by humeur
5 hours ago, Ksarul said:
Note that the Part number (WM113) is really important, as that also determines which part of the connector each voltage is attached to (there are several variants, as @acadiel discovered by accident many years ago).
Jim thanks for the additional information, I always look at the circuit before making a power cord.
I just needed to know the consumption of 5 Volts
Merci
Jim merci du complément d'information, je regarde toujours  le circuit avant de réaliser un cordon d'alimentation.
Edited by humeur
