J-DEE Posted August 13, 2001 Share Posted August 13, 2001 What are the output rating on a 5200 power adapter. I was thinking of tring my NES power adapter to see if the 5200 even works? Has anyone tried this? Quote Link to comment Share on other sites More sharing options...
DanBoris Posted August 13, 2001 Share Posted August 13, 2001 The four port uses - 9.3V DC@1.95 amp and the two port uses - 11.5V DC@1.95 amp An NES power supply will not work, since it outputs AC power not DC. Dan Quote Link to comment Share on other sites More sharing options...
Tizoc Posted August 14, 2001 Share Posted August 14, 2001 quote: Originally posted by Dan Boris: The four port uses - 9.3V DC@1.95 amp and the two port uses - 11.5V DC@1.95 amp I always thought it was the other way around: Four-Port: 11.5V DC@1.95 A Two-Port: 9.3V DC@1.95 A I thought the higher voltage in the Four-Port was for the automatic switchbox. i.e. because of the higher voltage it can switch automatically to 'game' mode like the nintendo. I don't know if this is for sure though. Get yourself a 5200 power supply, and don't worry too much about the output. I have tried interchanging the power supplies for the two/four port consoles with success. My 5200 is still working, and my house hasn't burned; but I'm not responsible if yours does. OK? Remember: Only use a 5200 power supply with a 5200 Quote Link to comment Share on other sites More sharing options...
