CabaretVoltaire Posted February 3, 2004 Share Posted February 3, 2004 What's the easiest way of editing sprites on the lynx? I haven't done anything like this in a while so I'm a bit rusty.. I used to do alot of C but for the last few years I've been working in web development (html, javascript, etc) which has made me stupid So please go easy on me. I have a sprite: Image[]={0x00,0x00, etc Which I want to be solid black for 64*32 pixels. First, how do I define a new line in the sprite? There doesn't seem to be anything in the sprite struct to define height and width, just hscale and vscale. Second how can I toggle individual pixels in this sprite between black white? Would something like this work? void TogglePixel(int x,int y,unsigned char *Image){ int ArrayPosition = (64 * y)+x; //gets the pixel position int nibble = (ArrayPosition & 1)<<4; //is pixel position odd or even? //two pixels per byte so divide by 2 Image[(ArrayPosition>>1)]^=(0xf0>>nibble); //xor by 0xf0, or if pixel is odd xor by 0xf } Thanks Quote Link to comment Share on other sites More sharing options...
eric_ruck Posted February 3, 2004 Share Posted February 3, 2004 You define a one pixel black sprite, then use hscale and vscale to cover the area you want...I'm feeling a bit hurried to look up the code now, PM me if you need and I can find it. Eric Quote Link to comment Share on other sites More sharing options...
CabaretVoltaire Posted February 4, 2004 Author Share Posted February 4, 2004 Hi Eric, I can't use hscale/vscale as I want to be able to set individual pixels in the sprite. I think I've worked out the sprite format now, I'm using a 64*32*1bpp sprite and I am able to toggle pixels on it fine However I'm having problems with the compiler and pointers, grr. Quote Link to comment Share on other sites More sharing options...
