iguana Posted February 17, 2004 Share Posted February 17, 2004 Hey, I just got a Odyssey 2 , but it does not seem to work. all the games are jumbled on the screen with flipping numbers and letters on it. I guess it needs to be cleaned, any ideas how to do this? thanks Quote Link to comment Share on other sites More sharing options...
Ze_ro Posted February 18, 2004 Share Posted February 18, 2004 Did you try cleaning the cartridges themselves already? A Q-tip with some alcohol should do the trick there. As for the cartridge port, that one is a little more tricky... blow in it a couple of times to see if that helps... if not, perhaps try rubbing a piece of sandpaper against the contacts or something. --Zero Quote Link to comment Share on other sites More sharing options...
