RMila75 Posted April 4, 2004 Share Posted April 4, 2004 Is there a simple way to clean the contacts on 2600 cartridges that include the spring-loaded cover thingie that keeps you from getting easy access to the inside of the cart? Quote Link to comment Share on other sites More sharing options...
The MilkMan Posted April 5, 2004 Share Posted April 5, 2004 mm hmm http://www.atariage.com/howto/clean_cartridges.html Quote Link to comment Share on other sites More sharing options...
Stingray Posted April 5, 2004 Share Posted April 5, 2004 You can slide the cover down by inserting pretty much anything that will fit (I usually use a toothpick) into either of the slots on both sides of the longer slot that the pcb goes through. As far as cleaning goes alcohol and qtips works on 99% of the games I've ever cleaned. -S Quote Link to comment Share on other sites More sharing options...
RMila75 Posted April 5, 2004 Author Share Posted April 5, 2004 I got it cleaned. I used one of those tiny suitcase keys to get the cover down. I had no clue it was that simple. Quote Link to comment Share on other sites More sharing options...
