5200 to A8 conversion library
Hello,
This is my 1st version of a 5200 to A8 helper tool called 52A8lib. When a 5200 game is assembled with this included, it makes it very easy to get the game up and running, because it replaces the 8-bit's OS (and all its overhead) with a mini-version of the 5200's BIOS.
I've included a test program that reads the A8's sticks as analog controllers, and also shows what key has been pressed.
Anyway, I'm hoping this can do a lot of the work for people wanting to convert their games. Please let me know what you think, and if you find any bugs.
-Bry
Edit: New version 0.4. Now example file assembles to A8 and 5200:
52a8_04.zip
Hello,
    -Bry
So, this is for people to create 5200 games? Or to convert 5200 games for play on the Atari computers?
Forgive my stupidity. :dunce:
It's to make it easier to convert a 5200 game to the 8-bit computers, by allowing you to shut off the computer's OS and embed a modified version of the 5200 BIOS directly in your game.
That's okay, I re-read my 1st post, and it's not abundantly clear. :)
-Bry
    -Bry
GOD I can't stand you smart people! :sad: :D
Can you write one to convert A8 games for play on the 5200 ? Like the bin files?
    -Bry
Unfortunately, the 5200 lacks the most important resource to do this...ram. So the games must be reverse-engineered and then modified to work within the hardware limitations.
I fixed a couple things and posted a new version btw... (I've been working on this all day and was in a hurry to post it before I went to bed).
The first version I posted had joystick values backwards, and would sometimes stop reading keys. I'll update the file by editing the original post to avoid confusion.
-Bry
Thanks for sharing Bryan :thumbsup:
I've got a couple of questions...
1) Would you still use equates.inc with this?
2) In your 52A8.h file you don't distinguish between A8 and 5200 equates...is that okay?
3) The comment in your testapp.asm says it should compile for an A8 or the 5200 but how? In the init_hdw routine in 52A8.asm you've hard coded values that are different on the 5200 (i.e. GTIA for the A8 is $D000 but $C000 for the 5200).
I must admit that I haven't compiled it yet to see if it works but it doesn't look like it will. :?
I've only included A8 equates. These would be used instead of any 5200 equates when assembling for the computer.
52A8lib cannot be assembled for the 5200, only the A8 (however, testapp is essentially a 5200 program). The idea is that it should be added to a project when porting to the A8 to emulate a 5200 style environment.
I'll post a new version later that shows how testapp can be assembled for the 5200 and the A8.
-Bry
I think I understand now. testapp.asm is a 5200 asm and you would use 52A8lib to convert it to the A8 :dunce:
:idea: So in theory you wouldn't need equates.inc for the conversion. You would only need it for the 5200 build. 8)
When I get a free moment I'll give it a run.
  • 4 years later...
Blame Atari. They could have made hardware & OS directly compatable between platforms if they chose to (and even utilized the existing controller input lines...an analog stick is just a pair of paddles, really).
Solution:
Get both machines. They are nowhere near as expensive now as they were to the rest of us back in the day.
Edited by Nukey Shay
  • 3 weeks later...
  • 12 years later...
I hate to dig up a decade+ old thread but I have seriously been thinking of converting my 5200 library to work on my XEGS (and yes I DO own both). I am frustrated that not all 5200 ports especially most of the homebrews including all of the Mean Hamster Software (now-defunct) titles in which I DO have .bin files of (for the 5200) are not available for the A8/XL/XE. Will this work with my Windows 7 Pro laptop with my SD cards for the multicarts I have for both machines (Atarimax 5200 and Ultimate Cart for XEGS)???
Edited by BIGHMW
To separate into multiple sentences.
6 hours ago, ZylonBane said:
Please rephrase your question using multiple sentences.
Will this program allow me to (somewhat) easily convert 5200 titles to 8-bit without having to study rocket science in order to do so??? I've been thinking about it knowing that there are tons of A8 titles that were actually improved when transferred to the 5200. Games like Super Breakout, for example, actually look, sound, and play better on Big Sexy than the OG A8 ports.
