Jedd Posted April 25, 2004 Share Posted April 25, 2004 I finally got a disassembler working on my Mac and decided I wanted to hack Pitfall by changing some sprites and stuff. The thing that sucks is that when I disassemble it, all the sprites are in hex. Does anyone know of a site or some software that can convert a bunch of .byte's into binary? Thanks! -J Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted April 25, 2004 Share Posted April 25, 2004 You can force the disassembler to do this for you. What you need to do is create a .cfg file that is used in the process. Try this... ORG F000 CODE F000 F3EE GFX F3EF F3FE CODE F3FF FAFC GFX FAFD FCA8 CODE FCA9 FCD6 GFX FCD7 FEAC CODE FEAD FEC1 GFX FEC2 FFFF Copy/paste that into notepad, and name it pitfall.cfg Now do this when you disassemble... distella -pafscpitfall.cfg pitfall.bin > pitfall.asm The values will still be shown in Hex, but each one will be on a seperate line, with the bitpattern commented off to the side And Hex->bitpattern isn't really hard to understand. There are only 16 different variations of the arrangement of the bits for each of the 2 hex digits... ---- = 0 ---x = 1 --x- = 2 --xx = 3 -x-- = 4 -x-x = 5 -xx- = 6 -xxx = 7 x--- = 8 x--x = 9 x-x- = A x-xx = B xx-- = C xx-x = D xxx- = E xxxx = F So a value like $86 would translate to the bitpattern x--- for the 8 and -xx- for the 6 ...i.e. x----xx- Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted April 25, 2004 Share Posted April 25, 2004 BTW Thomas has a fully commented reverse-engineered disassembly posted at The Dig. All the game graphics are represented in Binary values (1's and 0's). Quote Link to comment Share on other sites More sharing options...
Jedd Posted April 26, 2004 Author Share Posted April 26, 2004 Worked like a charm. Thank you! -J Quote Link to comment Share on other sites More sharing options...
ATARI TROLL Posted April 26, 2004 Share Posted April 26, 2004 I am having the same trouble but can't seem to reassemble a bin? Finally have alll the tools but its taking a while to get used to this! What tools are you using jed (DASM?). Cheers Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted April 26, 2004 Share Posted April 26, 2004 What message are you getting when you try to compile? Quote Link to comment Share on other sites More sharing options...
CPUWIZ Posted April 26, 2004 Share Posted April 26, 2004 What message are you getting when you try to compile? Not compile, assemble. EDIT: That's it, I am going home. Quote Link to comment Share on other sites More sharing options...
Nukey Shay Posted April 26, 2004 Share Posted April 26, 2004 Po-ta-to...pot-a-to Quote Link to comment Share on other sites More sharing options...
Jedd Posted April 26, 2004 Author Share Posted April 26, 2004 I'm running on Mac OSX, and to assemble code I use Dasm and macro.h and vcs.h. It took me about a week to get the darn thing working, so contact me if you have trouble and I'll help you out. As for disassembling code, I use the Mac version of Distella and the file above^ from nukey. Some trickery was necessary to get that up and running, too. To emulate I use Stella 1.2. Is that what you were asking? -J Btw I managed to change some of the sprites in Pitfall. So far, the scorpion is the robot from Berzerk, the logs are PacMan, and the gators are mutated ducks (they don't fit in very well, but they look funny ). If you guys have ideas for any of the other sprites, let me know, because I'm running out of ideas. K I'm done with this hack and I want to try and make my own game now. Here's a screenshot of what I produced in my long hard hour of hacking Pitfall: Quote Link to comment Share on other sites More sharing options...
