Wrathchild Posted August 28, 2004 Share Posted August 28, 2004 I reversed engineered some sound routines during my uni days (over 10 years ago!) and have just resurrected the code and tidied it up a bit so that it can be compiled with CA65/LD65. Also, I wrote a C program (for gcc or visual c etc) that will take the original data and output the tune's structure into a more readable format. Check out the files 'parse_??.c' The tunes are Draconus and Storm. The latter I wanted to use to see if david Whittaker's engine could be used to do the Speedball tune. For Speedball, the parse code extracts the instructions from the C64 SID data. Therefore I can be reworked by mapping the instruments etc to A8 instruments. However this is little beyond me at the moment and so if anyone wants to take up the mantle then please do! Maybe the base and drums from channel 1 should be put on one of the 8-bit channels for the A8? Also, the arpeggio support may need to be added. Also, the C64 extract method could be used to 'explain' other C64 titles for porting to the A8. Although the SID player can let you play C64 tunes on the A8 the overheads are high. So re-using existing players is still a good idea. One question though. These tunes are built as songs built from patterns of variable length and also the note length is set within the pattern. To me this is different from how you see a tune in a editor such as RMT, but does RMT save the tune data in a format similar to this. I like this macro method of writing a song, and actually it could make it easy for some people to write tunes this way? Finally, those with musical knowledge may wish to correct any incorrect naming/terminology in the listings, e.g. do I use words like vibrato trill etc correctly? Thanks & best wishes, Mark draconus.zip speedball.zip storm.zip 1 Quote Link to comment Share on other sites More sharing options...
andy_bernstein Posted August 28, 2004 Share Posted August 28, 2004 Dear Wrathchild, I'm looking at Draconus right now. I have a bunch of SID's to convert to XL/XE so I'll take a close look. BTW- thank you for the Bard's Tale introduction. Any chance you might finish the conversion ? AB. Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted August 29, 2004 Author Share Posted August 29, 2004 Hi, Good luck with the SIDs, shouldn't be to tricky to recode the parse program to work for different engines, e.g. Rob Hubbard. Just mapping those effects to the A8 is the hard bit Not looked at BT for while (same is true for World Class Leaderboard) but do intend getting back to them at some point. The last thing I did was to write (yet another) little C program to decode all of the C64 still graphics for the top left window, e.g. characters, buildings, monsters. A bit a work involved in getting the colours right on the A8, but should be OK. I'll put a little preview together (as with Barbarian) and post it up soon. Regards, Mark Quote Link to comment Share on other sites More sharing options...
samurai Posted August 29, 2004 Share Posted August 29, 2004 Are you able to convert sid music data to txt format, which RMT imports ? IT WOULD BE GREAT. Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted August 30, 2004 Author Share Posted August 30, 2004 Are you able to convert sid music data to txt format, which RMT imports ? Its not answered if RMT uses this kind of format? It might. If a mapping can be produce then I guess we could write a convertor. When a human reads the C64 output you can often make out the intructions for the instruments (because you heard them too). Hence you can substitute it with an A8 equivalent. Once a collection of these is made then a stock A8 instrument library can be defined which every song would then use (or draw upon, i.e. include those mapped). You still have to understand each original C64 playback routine, which typically requires its disassembly etc, although there can be quite a lot of commonality between routines. Regards, Mark Ps. Anyone have a disassembly of the Last Ninja 3 intro player routine (Reyn Ouwehand) before I do one? Ps2. Can I get a relocated Atari SIDplayer as the LN3 tune has Load: $5900-$CE65, Init: $CE50, Play: $CDD0 Quote Link to comment Share on other sites More sharing options...
