Happy_Dude Posted November 6, 2004 Share Posted November 6, 2004 Is there a way to compile this under linux ? I tried using dosemu but this is a 32bit prog and doesn't work under dos Quote Link to comment Share on other sites More sharing options...
+Mitch Posted November 6, 2004 Share Posted November 6, 2004 Is there a way to compile this under linux ?I tried using dosemu but this is a 32bit prog and doesn't work under dos You probably want to use Bruce Tomlin's version called sign7800, search the forums and you should find the link. Mitch Quote Link to comment Share on other sites More sharing options...
Bruce Tomlin Posted November 8, 2004 Share Posted November 8, 2004 http://xi6.com/hacks/ Quote Link to comment Share on other sites More sharing options...
